Made for 1 1/8" .120" DOM tubing. Fully tig welded by a certified welder and come with everything to install them to a factory K member. The inner gusset is made to run a 73+ sway bar, but could be modified to run a sway bar from earlier years. They have zerk fittings urethane bushings for long life. There is built in caster adjustment to allow more caster for stability at high speed. These arms also weigh 4lbs less than the factory arms. Contact me for more info.
Log in or register now.
