Every dog has his day!!
It would be nice if you can get it sitting to where you could set the driveshaft angle to where you want it, and then drill the truck brackets. That way you ain't gotta fool with it towards the back somewhere. I don't know if they sell the big block spool mounts, but O'Reillys sells the small block spool mounts for about nothing. Seems like you could do the same thing with small block into an early A if the need arose. Good job, and GREAT idea!
I have all that info. I have how far off the K frame it's supposed to sit and how far right and left. The height from the K frame will get the drive shaft angle spot on. This method will work for any Mopar chassis with the flat type biscuit mount pads. I'm probably gonna need some bushing shells, as I've hacked these up mocking things up. So I'll probably get a pair from the parts store. LOL I'll have to drill out the rubber, because the poly mounts don't come with shells. No biggie.
I'm very interested in seeing how it turns out. I just started doing something similar in my 66 Dart. You'll have to modify the passenger side mount bracket to a bit align with the flat pad on the K-member. That side has the k-member pad quite a ways out towards the frame rail. I'm sure you know this already. Keep us posted!
Where are you getting your poly bushings?
Here's my version coming along. I drilled and burned the old mounts out of the shells. Then pressed the new poly bushings and sleeves in. My original thought was to shorten the shells and poly inserts to fit the 318 truck brackets. After thinking on it, I'm going to widen the brackets instead. I believe that will turn out a lot neater than shortening the shells and inserts. Here are the mounts and brackets. You can see about how much the brackets need widening. Once that's done, I can locate the engine and straight through bolt holes and drill them. Over and done.
That should work out nicely, Rob. Great start!
That's very similar to how I'm doing mine on my 66 Dart. I've just gotta weld up the pass side pieces and bolt the bracket up to the k-member, then it's on to the driver's side. I like having those nice flat landing pads on the early A-body K-member.
Rusty, I have been reading a lot of different opinions on dynamic compression. My 361 is coming in right at 8.5:1 static and 7.65:1 dynamic (short duration cam). With the static compression I was thinking it should run on regular, but looking at the dynamic, maybe not?
I am running about 7.8 ish dynamic on mine and it has had no pinging or detonation at all.I feel sure it will. I think the trouble starts a tic over 8:1 dynamic. Especially with no quench and iron heads. Add good quench and it's a little different.
Closed chamber iron heads (516) but with pistons .065 down in the hole and a .040 gasket....no quench. We'll see.
Yeah most anything around or under 8 won't have much trouble. What octane do you get away with, Jim?
So far it has not mattered.
Where's your initial timing set, Jim?
20 at idle, 30 all in and 50 with vacuum
I used the FBO plate set the the smallest slot, 10 I think.I bought my old electronic distributor back, after I sold my stroker. I had welded the slots up to reduce the centrifugal to about 15 degrees, and it still has the vacuum advance as well, so that is good info to have. I will be breaking the cam in on the old points distributor, but then will switch to the electronic one later.
