Man that thing is looking great. Makes me wish I was around back in mid 64-65 to buy a new Dart Gt.
Kevin! Do you mean the upper of the two pictures? That's the one with the rachet control underneath the bumper jack! It would make sense to hold that jack in place with the spring and hold it in place in the hole in the jack.
Unfortunately this spring is the only one that I know of that's being repopped. Anyone else seing the 1965 spring?
I was able to mount the last seat tracks on the passenger seat when a question showed up. When the staff at the assembly line was going to mount the seats was the seat back mounted to the seat at that time? Reason for asking is that it would be way easier to mount the seat without the seatback.
Next question is which way the seat springs should be mounted? The ones on my convertible is broken so I have nothing to compare with!:banghead:
Ulf, I believe the jack should be mounted with the hook below the mast, not above it. The spring you're showing is the correct one. In order of assembly, the spring goes on the jack handle, the jack handle tip is inserted through the loop on the floor and the lug wrench end nests in the formed bracket at the rear. The ratchet on the mast needs to be near the bottom of the mast. Mount the mast on the bracket by the decklid hinge and the lower end nested into the bracket at the rear with the lug wrench end of the jack handle,. The free end of the spring now hooks into the base of the ratchet where that loose spring is wound (the spring serves to help hold the hook in place on the ratchet.) The hook of this little spring should probably face the front of the car. Flip the lever on the ratchet itself to allow you to operate the handle on the ratchet where the jack handle would go when you're lifting the car. Keep doing this until you have enough tension in that little spring to hold everything securely in position.
As for the seats, I'm virtually certain that the seats were installed as a complete assembly. The seat back would have been laid over the cushion, picked up from below by the front and back of the cushion and dropped into the holes in the floor pan.
At least the hinge appears to be in good shape!
Thanks for the pictures! That was for sure alot of help. I wonder how the spring looks like? Is it the 1965 one or the one from 1966?
I will pull the spring and take a close up when I get home from work today. To the best of my knowledge the spring is 1965 as it came with the car.
Keep up the great work Ulf!
Cheers
Roger
Here are a couple of pics I took last night of the spring, hope it helps you id as 65 or 66.
I have also included a couple of pics of the certicart mounted on the inside of the glovebox door in my 65
Cheers
In the second picture, I believe the loop on the right side of the photo goes around the jack handle and the loop & finger on the left side goes into the ratchet on the mast.
What I know of the only different between a 65 and a 66 spring is the way it attach to the jack. The lowerbloop wss the same aroung the bar. Can the old style spring been used with the 64 and 65 jacks but somewhere during 65 production they changrd?
This card on the inside of the glove box door, are those rivets repopped somewhere? I've never seen nos ones!
Entirely possible there was a running change. It would likely have been "use old stock until exhausted". The improvement of the later spring with the full coil at the bottom for the jack handle is that it couldn't slip off, which I believe was more than a possibility with the style in the pictures.
If the spring is even listed in the parts catalogue, it would be interesting to (a) see if the same part number shows up in '65 as in '66, and (b) if the numbers are different, if the '65 number supersedes to the '66 number.
I think it's pretty safe to assume that Chrysler wouldn't have cared other than knowing that the later style was an improvement over the original release.
I can check my 65 convertible seat bases; hopefully what you're looking for is there.
Kevin!
I think you have a point there! They probably just changed the spring during production year without any notice. Sometimes if there wasn't such a big difference parts were changed without notice to assembly personell as well as dealers.
I checked the partsbook and the spring is not listed in section 13 - 72 Bumper jack. First Picture showing the 1964 partsbook. The bumper jack was one unit for Valiant and Dart. The bar was the same also. For 1965 there was the 1964 model for Valiant and the Dart had a separate one. They have also added the hook with a special partsnumber. Finally the base and the bumper jack was avaible as a set. I don't have a August or September or January parts book edition so I cannot tell when the change was made. Any one out there that has an early 1965 partsbook that can check this up?
I was going to install the spring that goes between each seat track so when you adjust your seat both tracks moves. However it seems that the springs might be different between the drivers seat and the passenger seat. It seems that the spring should be longer on the passenger seat!! My seats didn't have a spring on the passenger side and my convertible doesn't either!!:banghead:
The reason I'm wonder is that the spring should be routed through a adjustable hook so both sides operates at the same time.
Yes, both latches would have to disengage at the same time, otherwise the movable part of the seat frame would just twist on the lower fixed portion. Would that wire connecting both seat track latches not go through that hook at the near side (looking at the picture) of the seat frame? That hook appears to be threaded, so that is likely where the adjustment on the tension is.
Damn, that looks good !
Outer ring toward the brake shield.
