robjkc
I got a set of the Vent frame gaskets from Gary Goers (http://www.garygoers.com/). These may fit as well on ebay from valleyvintage.
Jim!
Reg the paint. Yes, a picture would be sweet. I found a color sheep with samples from DuPont and they had some kind of dark saddle tan.
Here are the best pictures I could get of the upper dash paint. It's really hard to photograph color accurately. I'd say these photographs look greener than the actual paint. In these pictures the dash pad has been removed so you are seeing the body color paint at the bottom. The areas that were covered by the dash pad and by the windshield gasket are probably more accurate.
After cleaning it and uncovering the unexposed areas, it's not as dark as I thought. Let me know if this looks like yours, or if it looks like anything you've got chips for.
Also, my name is John, not Jim.
Here it is Ulf, notice how it is a real thin aluminum plate? The color, letters and numbers are all printed on. Also, where the "273" is, the numbers are raw aluminum, also appear to have a slightly brushed look to them, the outline for the lettering is also like this, just how the factory did it too. This is a very nice piece, not sure why nobody is making more of these, they sure sell a million of the cheapo stickers, these would sell too :glasses7:
In the pics you can also see the sticky backing, also there is some sticky glue on the edges that will have to be cleaned off, this baby is otherwise perfect.
I love when you find all this stuff Keith! You just made me walk out and check on the 65 Formula S engine that I just checked. You are so right. It is added on a thin plate of aluminium. I have seen this Before on Formula S air cleaners but not on the 273 Charger engines! Can it be differencies between the two? I daubt it but I'm not sure! I have the factory decal on the air cleaner in the convertible and that's just a sticker.
Thanks Keith! Where can we found some more input?
:burnout:
Thanks Keith! I will order a new decal and find an aluminium plate and cut it the way it should be. It looks like it is glued to the lid! Is it someone on this site that makes them the way they were?
Sometimes it talk a couple of tries before it get's right!
:burnout:
Funny you posted that air cleaner decal Ulf, cause I found something that might be of intrest to you. The original engine callout on the air cleaner was not a thin sticker, but an aluminum style plate that was glued down to the cover with the "273" printed on it with some type of paint or ink.
Silkscreened.
Glad they ended up at a good home, Dan!
I talked with a company today and I will make 10 or 20 of them. I will keep 5 of them and sell the restl of them depending on the cost. Anyone interested?
