Gave away all my magazines, about 10 boxes, when we moved 2 years ago
Australian six with Hemi head...no reason
I don't completely agree. They had to get the weight down. The smaller Hemis did run some great times, held the record for a short time, but it was the end of that era. The wedges could get more compression with a smaller dome piston (lighter weight), which gave them the rpm edge. The Corporation was hurting, factory support was gone, and the nhra really wanted the chevies to win anyway. Bob Glidden kept winning with his fords, which had to piss the nhra off to no end. Bob did win in 79 with the Arrow, small block. But the class was changing and Mopar just wasn't the main player anymore. Randy Humprey ran 8.46-159.01 at Fremont WWCS in 4/79 to set a new national ET record.
Anyway I want a Hemi just to have the history to go with this car. If I find a small one, it's icing on the cake!
I could do that, we will see how much cash I have. Still waiting to find some Hemi heads and a 396 or 366 de-stroked short block!
just the pump
That makes me skeered.
That's all that was used on the big blocks, if I remember right.
I kicked the motor over a couple of inches in the front and bingo, oil pump goes in with no problem. Has good clearance to the frame rail. So I put all the stuff on the engine and put the hood on. The breather clears the hood on an Offenhauser cast valve cover. So here it is all buttoned up. Only the headers are the hard part to do now and then we can start to put it all together. I was thinking next year, but now the fall looks possible.
View attachment 1715530234 View attachment 1715530235
