The bottom one looks like a horn relay, and I think the plastic one is a seat belt interlock relay.
You literally make me want to crawl under a rock.... You guys are in supersonic speed with the work..... Geeezzz
JW
Correct. Even if you choose to use the later seat belts out of the Dart, it won't matter because the wires on the seat belt retractors won't be plugged into anything. There are better than factory seat belts available, if you kind of want a 3 point belt so she will have a shoulder harness. I've used these belts in 3 of my cars so far, and will be using them in my 70 Duster, and the 65 Barracuda I just bought. Seat Belts Made In USA. Styles And Colors For Most Makes.Call:(302) 629-8508
JW
We have really only put maybe 40 hours (x2) into it (not counting the sandblasting of parts she is doing during the day when I am at work). I also have all the tools to do the job fast which makes a huge difference. With impact tools things come apart FAST.
I was a flat rate mechanic for 10 years I before getting my engineering degree so I learned to use my time wisely or I did not eat.
Congrats on making the car part of the family, legally.Long complicated annoying story but the Duster is now titled in my name! Thank you Gingers Title Service in Sierra Vista for actually reading the DMV documents as to what is truly required after the state of Arizona purges a title/VIN/Plate so cleanly they can find no record of it. The burden was on me to get a level one inspection because they throw away records. Gingers did not see where that was necessary when they researched. Anyway done.
I bought 2 flood light housing that are made to install on an electrical junction box for $2.98 each at Lowes, a lamp cord and 2 50W LED flood lamps. I had to steal the nut off one to get the other installed but I drilled a hole it the top of the blasting cabinet and wired in one of the 50W LED bulbs. WHAT A DIFFERENCE. That plus the rope light made the job 10x easier. Tomorrow will install the other 50W and it should be like the surface of the sun in there. Kaelyn will be SO happy. There are only a few more parts to blast. Friday we will start erecting the painting rack so we can spray Saturday!
Dropped the pistons and cam at the machine ship and picked up the LCA with the new MOOG bushing pressed it. Bead blasted and painted, meticulous work by Dave at Precision Machine as always.
Too many cars are getting parted and as scrapped these days because of difficulty getting paperwork.
Some states and counties are making it really hard because some people would rather just see all old cars disappear for good.
