Road test!
Spent 6 hours wrenching before heading out the driveway for the afternoon...
Thoughts on the combo- Fair low end (I can spin the tires a few times just by punching the gas, get on the converter a little will cause the tires to instantly go up in flames) mid-range is great with the top end lacking a little something. I'm fairly sure the 318 exhaust manifolds are choking off the top end charge. I plan on getting rid of them this winter.
Engine is quiet with some rocker gear noise at idle (normal for Harlan Sharp roller rockers) good oil pressure, runs cool. Seems to like lots of timing, more than the 318 did.
The exhaust manifold coating Calyx from Eastwood is fantastic, I highly recommend it. Goes on with a toothbrush and cures in just a few minutes.
Problems- The intake is leaking oil at the passengers front corner. I used the magnum end seals from Mopar, I should have used cork. I'll have to pull the intake off next week and fix it.
The power brake booster seems slow to release, I'll have to blast and paint the original and swap them out.
The power steering pump has a very slow leak... I'll have to keep an eye on it.
Gary
