Notanova73
The confusion comes from yeah I know diff carriers then why does a 90’s suregrip with 3:55 work is my confusion
That’s what I’m saying but all after that people make it sound harder then it is
I’m not good with texting and making it make sense I know that you need a different carrier, now my question is about the suregrip and how that’s okThe ring gear mounting FLANGE on the carrier is in a different place for the 2.45 gear. That's why you must get the carrier for the higher numerical gears. They move the flange to keep proper ring and pinion gear contact. They are NOT interchangeable because of that.
I’m not good with texting and making it make sense I know that you need a diff carrier, now my question is about the suregrip and how that’s ok
I understand all except the suregrip part since it doesn’t have a carrier that’s different from one to the other. Since the carrier is the main difference
Thanks for the help I know my questions seem like a 5 year old texted them but when your body is fucked up what can you do
Like I said I’ve been reading all I can about this and there was alote of misleading info so I’ll just try what you 2 have told meThe sure grip DOES INDEED have a different carrier. It too has a carrier specific for 2.45 and numerically lower gears and another for gears numerically higher than 2.45 just like an open carrier. I don't know WHERE you came up with that but it's WRONG.
Since I’m hear I’m redoing my 318/904 28”tire and going with xe268 cam,4 barrel,570 Holley street avenger, 302 closed chamber heads 1 5/8 headers dual 2.5 exhaust 2500 converter wanted 4:10 gears but wondering how the 3:55 would work or somewhere in between it’s not a daily anymore just a weekend warrior and never travel highway. Trying to have fun with the 318 before I install the big block( Dana 60 later for that)It's no problem. I get it. You're not familiar with it. That's fine. But you're asking the same question over and over. Read what we're telling you. Roy (SGBARRACUDA) and I have a combined 100 plus years of experience.
Prob lol. I don’t want to be digging up old stuff but... lol is there a difference in bearings ? There shouldn’t be I guess huh ?just want to make sure Ive never build a rearend and parts aren’t easy to come by locally.I was looking at gear sets and they come with the shims and seals when changing gears but it gives no differences in measurements.maybe I’m over thinking thisI think a 3.55 would be good, but that 570 carburetor is really going to keep you slow. JMO.
I'm not sure. Simply order new bearings for whatever application you're using the housing for. In other words, what did the housing come in? That's what you get bearings for. A 19xx whatever with an 8.2 rear axle.
This was for a kit with gears appears to be the universal my car is on there along with the xj Jeep which I have also
Ok cool because at first I figured diff bearings but apparently that’s not the case man really appreciate yah helping me out I’ll let yah know how it goes when I do itOk. I guess if your housing is among those listed, you're good.
What you think about this one compared to the Auburn type posted earlier this one is cheaper at the moment at 200.No problem. Good luck with it all!
What you think about this one compared to the Auburn type posted earlier this one is cheaper at the moment at 200.View attachment 1715688968
