Intake side..... not really porting, Just opening the pinch area about .030 around the pushrod, and removing the small hump for the valve cover bolt...
.finished up the Dremel work today. All I did was remove the 1/2 ring in the intake bowl and put some relief in the pushrod pinch point. I didn't touch the exhaust side at all.
Next will be the clean up and reassembly with the new Hughes valve spring kit.
I'm following your advice. I'm sinking them in the cylinder about .500 and holding them there for about 242*@050.
You need to sink the valves to really make power. I suggest a half an inch on the intake and three quarters of an inch on the exhaust .
Depends on which way you sink them, lol 3/4 on the exhaust only ? ha! ha! ha!.
O ok, what ever you say engine master. lol or is that race master.If he uses the compression enhancement method he doesn't need as much lift on the intake.
.Cold, wintery, so I'm sitting here thinking of just how easy, or hard this is.....
So does science always win??? The answer is yes. If science is based off of facts, but too often it's mixed with assumptions left from unknown details (which is really not science then).
So this is really pretty easy. I mean selecting a E.T. and knowing what it takes to get there. Except the X factor, which is all the "unknowns" about a true street car.
example:
So, a car weighing 3400 lbs w/driver, per say, needs about 8.3 additional horse power to gain 1 mph. That's just a mere 41.5 hp gain to add 5 mph, for illustration. Easy enough if starting with a basically stock engine. Now a 5 mph addition at the big end is great, no matter what your previous speed was. For instance, my 318 Duster ran 94.8 mph. An additional 5 mph would be 99.8. That gives for a 13.22 E.T. "IF" the car 60 fts to "bracket car" expectations.
Now I could spit in the wind and add 50 hp to either car, adding about 6 mph. That 6 mph give the 360 Duster 12.60's potential, and the 318 Duster 13 flat potential...……… but getting the "X" factor figured out is the hardest. That science is just to hard to obtain
I think you need to just start doing something damn impressive to get up here in the polls I'm still ahead of you and I'm not even in the race...If he uses the compression enhancement method he doesn't need as much lift on the intake.
Yeah that scale of yours only works to a point for sure. You can't just do x amount of horsepower does x amount of speed because as you go faster it personifies itself.Cold, wintery, so I'm sitting here thinking of just how easy, or hard this is.....
example:
Now I could spit in the wind and add 50 hp to either car, adding about 6 mph. That 6 mph give the 360 Duster 12.60's potential, and the 318 Duster 13 flat potential...……… but getting the "X" factor figured out is the hardest. That science is just hard to obtain
.Yeah that scale of yours only works to a point for sure. You can't just do x amount of horsepower does x amount of speed because as you go faster it personifies itself.
take the 1320 ft in the 1/4 and divide it by the speed you ran will give you a good rule of thumb of what your car's potential E.T. should be. It works if the car is set up right. Go ahead, get a calculator and start the divisions, of what you and your friends run for et and mph and see how accurate it is. The tough part is, this assumes you've set your car up to 60 ft, not the easiest for street cars.Yeah that scale of yours only works to a point for sure. You can't just do x amount of horsepower does x amount of speed because as you go faster it personifies itself.
No thank, you continue your bench racing as before....take the 1320 ft in the 1/4 and divide it by the speed you ran will give you a good rule of thumb of what your car's potential E.T. should be. It works if the car is set up right. Go ahead, get a calculator and start the divisions, of what you and your friends run for et and mph and see how accurate it is. The tough part is, this assumes you've set your car up to 60 ft.
Take a chapter from your own bookYou got nothing for this thread so take a backseat!
correct.And the faster the car, the more hp every tenth takes.
and summer time equals E.T. slips
LOL....
Which is where my precise calculations come in.
