j par
Well-hung Member
4 or 3/8 U-joint bolts and the Driveline comes out..Any distance 55 mph.
- Also, Dartfreak, it's hard on automatic transmissions to pull them down the road in neutral, rear tires on the ground for a length of distance.
driveshaft you mean, sure. then out comes a gallon of tranny fluid. Pull it backwards and quit making this difficult.... LOL4 or 3/8 U-joint bolts and the Driveline comes out..
So there's no difference and I tow truck picking the back end of a car up off the ground and just having the two tires trailing, then having the back tires down on a tow dolly with the front tires trailing?.
That was an everyday thing. Nothing unusual about it.
most tow trucks lift by the back tires. They don't drag cars down the road by bumpers... LOLSo there's no difference and I tow truck picking the back end of a car up off the ground and just having the two tires trailing, then having the back tires down on a tow dolly with the front tires trailing?
Oh boy do I have to drive out and its most simplest form for you? No duh! You put a little plastic plug in there that fits just nice and snug like the slip yoke. Or a spare slip yoke. people don't generally heavyweight things they're pulling to the rear.driveshaft you mean, sure. then out comes a gallon of tranny fluid. Pull it backwards and quit making this difficult.... LOL
.most tow trucks lift by the back tires. They don't drag cars down the road by bumpers... LOL
You are a word twisting son of a gun! They tow truck lifting the back tires is way different than the back tires being down on a dolly...most tow trucks lift by the back tires. They don't drag cars down the road by bumpers... LOL
DARTFREAK..... here are your two choices with a dolly:Oh boy do I have to drive out and its most simplest form for you? No duh! You put a little plastic plug in there that fits just nice and snug like the slip yoke. Or a spare slip yoke. people don't generally wait things they're pulling to the rear.
Nothing, steering wheel lockwhat does the steering wheel do when pulling backwards.
And...DARTFREAK..... here are your two choices with a dolly:
- crawl under and removed drive shaft, wire a spare yoke in the tranny, then when you get to the drag way, crawl under and remove tied in spare yoke, and re-install drive shaft.
- pull it backwards.
did you try towing something?? Bwawhahaha
Safest way to get your car to the drag way is...… DRIVE IT!!! It's a street car, right?Dart freak don't do anything so stupid and dangerous..
Honestly I really appreciate all your thoughts and stuff here on the forum, but this one I am going to tell you is got to be the stupidest suggestion and I've ever heard anybody give. Towing anything weighted to the back on a freeway or highway is absolutely complete stupidity.did you try towing something?? Bwawhahaha
Remember, Dartfreak, you can't back up with a 2 wheel dolly
And honestly, you just showed me something about you, I'll say no more. Weighted to the back is a killer on a trailer and will cause sway, or an accident. 2 wheel dolly's don't have the same weight distribution on the tongue as trailers. Weight on the ground is no effect on how the dolly pullsHonestly I really appreciate all your thoughts and stuff here on the forum, but this one I am going to tell you is got to be the stupidest suggestion and I've ever heard anybody give. Towing anything weighted to the back on a freeway or highway is absolutely complete stupidity.
And you loaded your duster backwards and did 65 down the freeway for an hour to the track?And honestly, you just showed me something about you, I'll say no more. Weighted to the back is a killer on a trailer and will cause sway, or an accident. 2 wheel dolly's don't have the same weight distribution on the tongue as trailers.
I've owned a two wheel dolly for years.....
why do I bother…. really.And you loaded your duster backwards and did 65 down the freeway for an hour to the track?
When I towed my cars with a TRAILER, I made every effort to put the weight a little more on the front.
When you pull with a dolly … IT DOES NOT MATTER. You are NOT picking up the tongue of the dolly no matter HOW much weight is on the ground rolling...
so you admit you have no experience with this and you're willing to take chances with somebody else's life to prove yourself?I may not be that knowledgeable but I sure don't experiment with my life.
You do relize my boat has 900 pounds of running gear out the *** end.Honestly I really appreciate all your thoughts and stuff here on the forum, but this one I am going to tell you is got to be the stupidest suggestion and I've ever heard anybody give. Towing anything weighted to the back on a freeway or highway is absolutely complete stupidity.
you asked how I pulled my car to the drag way. I had a trailer. But, I also had a dolly and I towed several cars several ways in several directions. Carry on, i'm out on this towing subject.so you admit you have no experience with this and you're willing to take chances with somebody else's life to prove yourself?
Agreed just like any boat trailer. the wheels are almost all the way at the back for a reason.You do relize my boat has 900 pounds of running gear out the *** end.
