you are right he tried a bigger one and it gain about 10 hp more. but this is the carb I have so I'm good with it. not worth buying one right now.I bet a swap to a bigger carb would be worth an easy 10 hp or more.
I don't like your cam. You could have used the 284/.484 106 LSA MoPar cam and had the same vacuum at idle and picked up power everywhere.
RustyRatRod just posted three great links in the I don't understand cams thread. I suggest you read those threads. They have every good info.
Also, can you post the BSFC, BSAC and BMEP numbers. Can't tell much more with just the numbers you posted.
BTW, if you blow a head gasket on the dyno by pulling the engine down, the dyno operator has issues. I'm not a big fan of pulling them down farther than actual bottom of engine RPM range, but these guys are correct. He should have pulled it down to 2500.
[email protected]! 1.6 rocker equals a .516 lift!I don't like your cam. You could have used the 284/.484 106 LSA MoPar cam and had the same vacuum at idle and picked up power everywhere.
Yawn... and you build your engines,your way... Just ,my opine.... He has plenty of mechanical compression,to pull a .484 Purple shaft...(have you run one,properly tuned?), good cylinder heads(Edelbrocks,are.. enhhh,o.t.b....) need real cam timing,to run....There are several ways,to get there.... I would use a cam,instead of expensive head porting....There's literally no chance in hell a 241/241 with 106 LSA is going to have the same vacuum at idle as a 231/231 with a 110 LSA.. He'd be looking at a loss of 3" vacuum at idle MINIMUM. You need to stop.
OP, I don't know what's going on with your torque curve, but it shouldn't dip like that between 3500 and 4500 RPM. the peak should be right where the dip is.. and a higher figure. I firmly believe 480lb/ft should be within reach!
IMO It should look more like the attached file.
NOTE: the light blue curve is a proposed spark curve with a multiplication factor of 10, So if it reads 350 @ 5400RPM it means 35 degrees advance @ 5400RPM. This is just a guideline, or an example of an optimised ignition advance curve for an imaginary engine of similar specification to yours, SO DO NOT REPLICATE THIS CURVE EXACTLY. but if your spark curve is deviating from this by a large amount (say 20%) in the mid range where you have your dip, it may indicate that your ignition/spark curve needs some tuning attention to remove the dip.
The low end of this spark curve, under 1800RPM should also probably be disregarded, too. Since this is an example of a full throttle pull at maximum load. (an unrealistic scenario for an engine speed that low in your application)
breaking them in on a dyno is the best and the safest IMO. You walk away with a turn key engine that has a decent base tune.
Was on a engine dyno. I'll get the cam specs later. it's a 340. with .030 bore, aluminum heads from performance world which look similar to edelbrock to me.. aluminum ld4b intake that was port matched. 1.5 roller rockers. 600 cfm edelbrock carb. 91 octane fuel and 10 to 1 compression. engine is buit for street only car with power brakes. thanks for the reply it has given me some ideas on questions to ask.
The timing.in my opinion the cam is over advanced (just my 2 cents)
