Wilma
Yup 46RE.Are you using a 46re? The use of switches sounds like you have an rh.
Converting from 4x4 to 4x2 involves switching to the 2wd overdrive. Get a later one, they improved over the years. As for the computer bit, not so easy to just put in an earlier valve body. Better to start with a 95 or earlier unit. Shouldn't be too hard to find a first gen Dakota or 2wd Ram truck in a junkyard. I just pulled a 42RH for $200.
Really? What,no computer? Just switches? What about the valve body? How is shifting controlled?Yup 46RE.
Agreed.Only problem is the 2wd part.Not happening here. In Alberta yup,probably lots.Find a 2 wheel drive pre 96 Dakota with the v6 or v8.
How far is Alberta? By the way why not use a 42 instead of a 46?
The number designation is it's torque handling capacity. So a 42 is weaker than a 46.Really probably makes literally no difference.Trans will get built to handle **** anyways.I'll probably consider them all.Important part is no electronic trans need apply.
Care to elaborate on this at all? I’ve looked (a few years ago) for a stand-alone 46RE controller and came up empty. Few guys on the Dakota sites were trying to figure it out but no one I could find had one running. Any links or info?There is a trans controller for an RE, but it's almost 800 bucks. I feel like I remember somebody putting a 727 valve body in a 46re, but I'm probably mistaken. Maybe check www.car-part.com to see if there is a 518 near you. Might pick up a good rebuilder fairly cheap.
I actually just stumbled on it the other day. I swore the Compushift worked on the RE transmissions but they are for the RH.Care to elaborate on this at all? I’ve looked (a few years ago) for a stand-alone 46RE controller and came up empty. Few guys on the Dakota sites were trying to figure it out but no one I could find had one running. Any links or info?
That's the only one I know of. I really tried with the owner of US Shift. Super nice guy and they make a nice product, he just didn't think it would be as popular as I did.Posted at a similar time.
Oooof! $700. Probably more practible looking for an 46RH or a 518.
1970 Dodge Dart with a fibreglass front end.400 stroked to 451 or so.Dana 60.Finished engine plans were initially stage VI max wedge heads.Deeming them impractice,really want this car to be driveable.Thinking along other lines now.
Not yet! Kinda need the trans first lol. Might actually be easier and cheaper sourcing a trans out of Washington state.Spokane is only 2.5 hours away,plus much bigger market.Do you have a small block to big block adapter plate?
Care to explain how this works? I'm baffled.The RE NEEDS a computer to shift...Yup 46RE.
Ok.Then the o/d needs a steady voltage supplied by a switch?Lock up same idea?So there IS a simple way to make an Re work?He's using a manual shift valve body.
I see two ways that you could do it.
1 is to just have the power going through a switch on your dash or console or wherever going to the overdrive pin and another wire and switch going to the lockup pin on the side of the transmission.
That way you can physically Lock it or overdrive it when you want to.
2 Is to use pressure switches to control when it shifts into over and lu. With a switch on the console or dash to shut them off.
You would want to make sure it only works in 3rd gear either way.
I would love for the actual poster using this to give some details.What say you Wilma?
