.480/230 cam in an 8.5 CR 360?
Maybe not optimal, but millions of builds have been built that way and turn out fine. Not everybody is looking to wring every single bit or power out of one. Some people need to use what they have.
I get that. Just because it’s being done doesn’t mean it’s good.
Is the OP buying a cam or using what he has?
Now I have to go look…
Basically some will be satisfied with the results of this cam others won't be, question is if the OP will be or not, and only he can decide that.
He seems pretty bent on using the cam, which is fine. It can be made to run really well leaving compression right where it is. The problem is, you cannot convince people of that. Yeah, it'll make more power with more compression, but I just bet it's not worth the extra money spent.
don't let perfect be the enemy of good enough. you want every last drop of performance? then splash the cash and build that ricky racer motor. otherwise knock it fwd a few degrees and ship that mother trucker.
it'll be fffiiiinnnneee.
It just will not work! Call any cam mfg. and ask them. He would be much better off just using a stock 318 cam. I'll bet he could get one on here for free + shipping. You are giving the man the wrong info.
I’m convinced it will run relatively well.
But this forum and multiple others are FULL of guys complaining about “soft bottom end” and things like that.
It’s rampant.
I’m not a Freiberger type who thinks just getting it running is the cats ***. It may be if you are building multiple cars for a tv channel, but for something you want to drive and not keep screwing with you fix it.
In the grand scheme of things a change of cams is relatively inexpensive. It’s far cheaper than trying to get the compression up.
I don’t step over donuts to grab a dog turd, isn’t my way.
Just because you have something doesn’t make it worth using.
Next up, the OP will need a different converter and more gear to get it correct.
I looked at what rolling the cam to a 103 ICL. The overlap triangle gets murdered.
You can do it, but if the OP found something with 10 less degrees duration and put the LSA at 106 he’d be far better off IMO.
Richard Holdener basically say same thing from all of the dyno runs he's done the curve is gonna be pretty much the same just it's gonna be a little higher or lower overall depending on the cr.
.5 cr ain't gonna make much difference.
It’s rampant.
I don't disagree with any of your points. That said, the fact is, we could pick apart one of your builds and point to where you could get more power. You always leave something on the table with every single build. I'm not advocating inefficient builds here, I'm simply saying there's nothing wrong with using what's there and building and tuning it to be optimal for what it is. That's kinda what we do with all builds anyway.
There's tons of areas where we give up optimal power/performance from tires to air filter.
Question is, what set of compromise are right for the OP for this car at this particular time ?
He said budget was not the issue. He has a quality core and good lifters. I personally will never run a new hydraulic flat tappet cam, unless I had what he has. There is no sound reason to stay with that cam as ground.
For his application, keeping that cam is nothing more than polishing a turd.
I doubt the OP is looking for a street killer with his 65'. His original setup with a little bit of cam advance, and a good tune will make a nice street cruiser that sounds good. And probably run some 14's if he really feels the need to lean on it.
Yep, i'm one of the old guys that have made something like this work... :)
I wouldn't go that far, but I agree there are "better" grinds to be had.
I agree. But I’m not asking for opinions.
I gave him mine. Get the colored t cam and stop using bad hacks to fix issues.
Selecting the correct cam the first time is always cheaper.
I’m patiently waiting for the thread where the converter is too tight and it’s still sloppy down low.
I’m not a prophet but I’ve seen this before.
And the OP can fix it relatively painlessly if he wants to.
Or he can cut a corner.
Edit: there is a few guys I listen to about power on here. It ain’t many though.
