Then u have a 4.150 crank.I have 7.1 rods in my 505 ------------------
Is there a differance in crank quality between the two? I would go with the better one if so, if not, 543. I like the bigger motor because it will be making max hp earlier. If you have great traction then consistancy will be a touch better due to the lower rpm power. It will also be faster. 38 cubes and a full point compression means a lot.I got a couple of friends that feel my Indy SR heads (flow 350/250)will be more at home on the 505. They don’t think they are up to the task of feeding the 543. I do have a Super Victor and a 1250 Dominator to top them off. Both would be using the same roller cam. Comp 275/[email protected] 108 .625 lift. I do have 1.6 rockers also. 543 will be 11-1. 505 12-1 Compression 543 uses external oiling. 505 internal oiling. What does the FABO crowd think? This is for bracket racing. I will need to use a 4.5 gasket to clear the combustion chambers in the SR heads. Thanks. Kim
Same kits. 543 is 11-1. 505 12-1Is there a differance in crank quality between the two? I would go with the better one if so, if not, 543. I like the bigger motor because it will be making max hp earlier. If you have great traction then consistancy will be a touch better due to the lower rpm power. It will also be faster. 38 cubes and a full point compression means a lot.
That’s 300 thou shorter piston than mine. Yours must look like a hockey puck. KimNot so my friend 4,350 bore , 4.250 stroke , bought a race balanced kit from Hughs engines , mostly scat stuff , icon pistons .Lots of them out there !--
440/505 .
Bob, I have a 505 kit. It has a 6.8 rod and a 4.25 stroke crank. This is the Chevy size of 2.2 bearing size. I don’t pretend to know everything and I like to learn stuff as well as the next guy. Here is a 505 piston in the top pic. Uses a 6.8 rod. Here is the 543 piston in the bottom pic. Uses a 7.1 rod. My kits are the same brand name. KimNo, actually fairly decent , did a lot of studying and searching before I settled on this size. You need to do some study on it , their fairly dependable , piston is longer than u might think . I`m surprised u aren`t up on it , as much stuff as you post for sale .
Yes it is. That’s why I want to keep the revs to 6500 more or less. They have a support rail for the rings so that probably won’t be a problem. KimMan that 543 pin is way, way into the oil rail. Crazy.
IMHO gearing for 6200 at the stripe with a 543 and SR heads would make some sense. No need to run a combo like that above 6400 and using a tall gear to keep finishline revs down will enhance engine life a lot. A 2.45 low gear combined with a 4.10 rear and 30 inch tall tires puts a very serious load on the tire contact patch at launch. A taller rear gear or tire will help a lot and due to traction issues will probably be faster.Yes it is. That’s why I want to keep the revs to 6500 more or less. They have a support rail for the rings so that probably won’t be a problem. Kim
I don't think the pin in the oil ring is an issue at all, I think it's like a wives tail
Dude with the black & red stripe 69 dart ?It must not be a big deal. I bought these pistons off Jason Digby owner of the one time fastest car on leaf springs. He was running a nitrous combo then going I think 4.40’s. I bought them when he switched to a turbo.
Predator engine ? Lol, I just looked it up, the cars called tooth jerker because hes a dentist.
Cool **** !Yep. I bought his rods, pistons, converter
