- Joined
- Mar 17, 2018
- Messages
- 15,145
- Reaction score
- 35,634
Bolts are same size and thread pitch just .5 shorter. Metric. I just took a sample of old bolt to hardware store found a nut that fit it to establish thread pitch as I am not always sure on metric! Once I found the correct nut I then went to corresponding size bolt bin and found one that was shorter than my sample. And I bought some super long ones to assist in the reassembly. I used the long ones as placeholders. By being super long I could insert them thru pan,gasket,tray,gasket and into block and let it hang. That allowed me to get the gaskets all lined up and a bolt in each hole prior to cinching up. That and some gasket stick em! Then I just started replacing long bolts for correct size one at a time. Full disclosure Best Neighbor Ever was called in for another set of hands! He loves Jack and Coke so I keep a bottle on the shelf for him. He is a true Mopar guy as well! Has a Demon too. We did it with engine hanging from chain fall, this increased the complexity ten fold. In a real shop I would have simply spun the motor upside down on the fancy engine stand and installed it all upside down easy easy![QUOTE="And oh by the way the factory bolts will not work going back into the oil pan. You need.5 shorter ones. Just more of those really cool tidbits that just keep getting in the way.
Oil pan stud kit? Are these bolts the same size as other pan bolts?
Mike
CichliDart
