I am North of Fargo the one thing we do not have to worry about is heat! Hah! Might be 60 today? Closest city of any size is Winnipeg Canada.Great progress. It’s been intolerable hear from the heat so very little is being done on mine so it’s nice to see someone going forward
So this weekend I am focusing on fabricating the tranny mounts on underside. I purchased a handy dandy mount but it fits a 56 and I have a 60. Bummer! The OEM Mopar TR60 has a very different mounting configuration than the GM boys. Tranny is same mounting tabs etc very different. I am in hopes I can salvage the top portion of the purchased mount. Should anyone be interested in the lower for a 56 PM me and I will make you a smoking deal. I included a picture of all you need to fabricate the mount! Hah! Cardboard and scissors! Anyway as you can see by the pix I have it rough cut and installed. I will now take it out and pretty it up and box it all out. My fearless hound "Hemi" recently had ACL surgery thus the shaved goofy looking leg. She is gorked out on meds. No running or jumping for five weeks. Try telling that to a 100 pound Shepard! Holy smokes it has been a pain in the butt. PS I used 3/8 material but really that is overkill it is just what I had laying around so rather than wait I chose to get it done Farm style! Lord knows I could tear up a prybar in a sandbox! Heavy is good!I am North of Fargo the one thing we do not have to worry about is heat! Hah! Might be 60 today? Closest city of any size is Winnipeg Canada.
Old Cuda,Looking good, you keep reminding me of all the work ahead,
But giving me motivation!
Mine is a 2010 same as yours. Regardless of methodology or system purchase you will have to pay some one to reflash. Check out Hot Wire in Mena Ark. ask for Chris he owns the joint and is a wealth of knowledge. I was so unlearned on all things modern motor I had to look up half the plugs as I could not identify them. I had never even heard of an anti knock sensor much less where they were located. Hint, you have two of them and you will need them both.They are located at base of motor on both sides and they look to be a ground wire, they are not! Hah. One of my many mistakes and incorrect assumptions I made while sorting out wiring!Sublime
Thanks, . I am not an electrician for sure, all help will be appreciated. And pictures help an old hillbilly out.
I'm trying to wrap up an old Scout I'm re working, and keeping the boss lady happy with a new roof on the house, then it will be time to dive in.
I see the transmission mount is in work, you will be down to the short hairs in no time.
What's the plan with the computer, mines a 2010.
I'm trying to research info and start picking up the parts I need as money permits. You know how these projects go, a lot of TLC (time, labor and cash), lots of cash.
Your way ahead of me so you can bet I'll be in contact.
Too bad I'm so far from your shop, I would be all in.
Thanks again, really a cool project.
So I had some accurate input, " hey geek why no photo of completed unit in car?" Fair question! Hah! So here is a pix of the completed unit in car. I will trade bolts out for some grade 8s next time I am in town. I also included a pix of the top hoop as that is where I am heading next. I sipped a couple adult beverages and decided to step away from it today. And yes the low profile mount was from existing donor car I then modified it to fit in the Demon. My fancy schmancy purchased mount did not have a prayer of fitting. By no means a complaint as I purchased it knowing it was for a 56 and I was doing an OEM Mopar 60. I figured I could use some of it and save some time. Not so much! Did not use any of the bottom but appears I can use most all of top hoop with exception of mounting portion. The bottom portion is heading to a FABO neighbor in Winnipeg. I will take next week off to see a brand new grandson. I am taking him a Benelli pump 12 for his Birthday! I figure his dad will borrow it till he can lift it! As frustrating as this conversion is days like today really make up for all the beating your head on the wall days. I am super excited to have the tranny supported with no chain or 2x4s involved! I am going to mess around and have a car one of these days.Good deal, giving me some ideas.............. More pictures....................
So I decided to get on top of the car for a change rather than under it! Started mocking up and installing radiator. That went so easy I thought while I am here I will,set up CAI box. As you can see by the pix, back to the car hates me and will fight me every single step. The fitting for temp is right on top of Power steering pump and discharge intake box is fighting for space with shock tower bracing. I swear you have got to hand make every single honking piece, nothing is easy! So any way after stomping my feet and muttering I simply cut the CAI and will remitre it and weld it back up. Underneath all that fancy chrome it is aluminum. I will check outbuildings and see if I have a piece of aluminum convey pipe I can cut up if need be. This car is gonna make me crazy.Hah.Another hurdle down. Looking good!
Those green bottles make it easier to cope with engineering complexities though!!So I decided to get on top of the car for a change rather than under it! Started mocking up and installing radiator. That went so easy I thought while I am here I will,set up CAI box. As you can see by the pix, back to the car hates me and will fight me every single step. The fitting for temp is right on top of Power steering pump and discharge intake box is fighting for space with shock tower bracing. I swear you have got to hand make every single honking piece, nothing is easy! So any way after stomping my feet and muttering I simply cut the CAI and will remitre it and weld it back up. Underneath all that fancy chrome it is aluminum. I will check outbuildings and see if I have a piece of aluminum convey pipe I can cut up if need be. This car is gonna make me crazy.Hah.
In Marines we called it aiming fluid! Hah! So I sorted out mitres and have the CAI going my way. The connection is moved back out of the way from power steering and the filter now has room to share with shock tower support. I will still need to fabricate some kind of isolation box but that is for another day!Those green bottles make it easier to cope with engineering complexities though!!
Hope my handy dandy powder coater can do aluminum? That technology is ever evolving.In Marines we called it aiming fluid! Hah! So I sorted out mitres and have the CAI going my way. The connection is moved back out of the way from power steering and the filter now has room to share with shock tower support. I will still need to fabricate some kind of isolation box but that is for another day!
I am for sure leaving it to the pros! anyone has any ideas on painting or coating the plastic valve covers let me know, I have searched and not really found any replacement dress up pieces? I am going to take a break for a week or so and go see a bunch of hillbillies and rednecks in Arkansas and Oklahoma! Oh wait that is my family! Hah! We have a new grandson who I figure desperately needs a fine pump 12 gauge for a birthday present! Hope all y'all have a great week and weekend! And remember....as my boss once upon a time sat at his desk shaking his head told me "there is nothing worse than an articulate redneck" be safe see ya in a week!Why would it not? Powder will adhere to any metal -- it's all in the prep and gun settings to get the best results and adhesion. Aluminum can be tricky though (especially old used cast pieces) so those are best left to the pros.
