63 Dodge Dart, now let me see;)
lol, you're funny;) Funny is good;) hm, no wood, but I have a cushy moving blanket, no deck lid latch, so he'll just have to hold it down while I check and mark. hm, just going to go put tools away, and clean up~ I do like organization, or say, less messy, varies from day to day~ lol
You go girl !! :) That looks great. Do you have a semi small piece of plywood laying around? If you do, lay it over the spare tire well before you crawl in there with the trunk lid shut to mark your hinge supports before welding them. Having a flat place to lay and wiggle around on beats the heck out of fighting that tire hole! Just in case your husband won't unlatch the trunk to let you back out, you can lay a screwdriver in the trunk to twist the latch with...lol. My veterinarian once told me to lock my wife and dog in a car trunk for an hour, and watch which one was glad to see me when I let them out! So far, I ain't been brave enough to test his theory!
:rofl:
The shifter hump as arrived;) I was getting a little worried, but usps came through~ Marc (bb66cuda)(did a great job packaging, now a little trimmin and all will be GREAT! ;)
when i swapped to 4 speed in my 68 valiant i fitted small nutserts to the original floor and tunnel around the new hole. that way i could bolt the 4 speed hump in place which with it removed made installing to shifter rods much much easier. just something to consider before you weld yours in place for good.
neil.
neil.
Neil, I like your idea!! On my triumph tr6 ,for the trans tunnel, I welded in 1/4 weldable nuts, nutserts sounds easier;) Do you buy those as a kit, like rivets?
here's what it looks like and the superb access a removeable panel allows you.
neil.
Thank you Neil! You answered my questions which are in my brain! ;) Do I just cut the hole/access, then put the transmission/shifter up through the hole to make sure the shifter is centered to the hump? I don't have a shifter yet:( guess I'll put out a wanted shifter post now.
I'm converting my 65 Barracuda to a 4 speed also. I'm going to hold off welding my 4 speed hump in until I get the transmission mocked up. My hump is a 64-65, just like yours. I might be overthinking it, but I'm guessing with that itty bitty hole for the shifter handle....the hump placement may need to be pretty precise. 66 model humps had an elongated hole for the shifter, like later A bodies.
yes, it appears to be a tight fit and I too wouldn't weld, or in my case, I'm going to do what Neil did, bolt it in, but still want it centered perfectly;)
oh, got a call from the machine shop regarding my slant 6. It was .30 over already, but he said the cylinders were not in good shape, so we're going to .40 over, needed valve guides, so a valve job. He's sourcing the pistons. so that's that:)
i pressed the 'hump' down while wiggling it and it settled in one place fitting the floor contours all round. i drew round it and cut the floor about 3/4" in from that line. the hurst comp' shifter with 'a' body bracket lined up in the hole spot on, but as you say the hole's much bigger in the later hump. worst way you elongate the hole and use a different (later) boot and bezel.
neil.
I was a little motivated today~ got to test fit the 318, looks like the distrubutor may work, it'll be close, but I'm waiting on the correct motor supports to see what that does. A radiator may prove to be a challenge;) Any ideas which exhaust manifolds might work better. The one on the drivers side probably won't work due to interference for the steering column.
think I`d adjust that firewall about 1/4-1/2'' before final assembly/hammer .
lol, Famous Bob, the V8 is old news~ I'm going with a slant 6, with the super six upgrade. Engine is getting a mod for 9:1 compression;)
Neils picture:
Do I cut the dog leg out too or leave it like I have it here? and what purpose does the piece serve?
My plan is to cut straight, being careful not to cut the crossmember. Then tack the dogleg down to the floor pan. On the shifter side, I will leave the floor pan metal on top of the crossmember to strengthen it and also keep crud out. The factory did it that way, so it's good enough for me. :)
agreed, cut it straight first and see what's under there. if doesn't ' need' to be cut out why do it. that bit can still be bolted down though. on my 68 i found the tunnel wasn't spot welded to the crossmember on the section to be cut out. almost like ma mopar knew we'd be cutting it out for a 4 speed, lol.
neil.
So, could the yellow line represent not cutting any further than that? leaving metal in place. Neil should be here soon;)
Neils pic again;)
it only costs you the cutting discs to cut less first, then cut more if you need to.
oh, and anyone wondering what the 'shift lever' is it's an old alternator bracket i used for setting up the shift rod lengths (i didn't have the right ones, lol).
neil.
