Sergey
Happy about this little bumper mounts. Starting on the radiator and fender supports
i have Steve Magnante book about altered wheel base cars, i followed his advice and used his research base on photos of old cars the most, i just tried to move the front as far as i can, and independent suspension lets me move it further too.Sergey,
How did you decide on how far to move the front and rear axles and drive train? Are you aiming for better weight distribution? Are you planning on using a wheelie bar? It looks like you know what you are doing.
Thank you!! i’ll redo them, i’ll try to do a research, so i’ll have a better idea, hard to picture my head.re the panhard mounts, i'd brace the axle brackets diagonally from maybe halfway up either out to the axle tube or in to the diff casing. or better still shorten them and lengthen the chassis brackets. so they're about the same length. there's a lot of leverage on those long brackets as they are. if the bar gets too close to the diff by lowering it it can be bent to clear. that only makes bar length changes more awkward but once set that shouldn't ever need altering.
neil.
i think it’s 15 gallon, way too big, i wish i could go with a smaller oneNice work!! What size fuel cell is that?
