Sergey
Also couple photos from when it ran and a boobie
I put a BMW radiator in my 65. Required a little fab work, but shouldn’t be an issue for you. Ebay GT45 + 5.9 Magnum + E85 blow thruspun a bearing, waiting on my 408, actually just got dart back in a garage on 3rd of July, want to run with a hood, so working on the conversion to spring hood hinges, worked all summer with no days off. But will start working on it again. May be polish the crank and will put magnum back.
will keep you updated.
Want to put a chevy style radaitor, so it’ll fit better and want to cut out splash guards/inner fenders to fit headers better.
Also want to make tubular brackets for radiator and fenders, just picked up 1 1/4 tubing today
wow! that’s so cool! i don’t think i ever seen straight axles with coil overs only with leaf springs! i like it! i actually was thinkking about doing independent front suspension i got from art morrisonyou fitting a straight tube axle? my old anglia wagon gasser had the rear axle 4" forward and the front tube axle 7" forward.
looking forward to the progress
neil.
that’s what i wanted to go with, one of Dick Landys altered cars was not a straight axle, that’s the direction i wanted to goan altered wheelbase car without a straight axle up front? whatever next. especially when a complete setup from speedway is such a good price (that's not what i used though, lol).
neil.
i want to do as much forward as i can, 15”, but ive heard about the rule of 10% if i have 113 wheel base i can move it only 11”, so i’ll might do that, not sure yetWhat are the plans for the back end?
That'll look awesome! I know you've probably seen it, but here's a great series of videos on building a altered wheel base early Dart:i want to do as much forward as i can, 15”, but ive heard about the rule of 10% if i have 113 wheel base i can move it only 11”, so i’ll might do that, not sure yet
also i want to move the engine a little inside i had problems with clearing the radiator
i got them from Thadeous, he has a Demon too, not from Paul though. They just bolt direct on, but i stead of 10 studs it’s only 5.I had a question, how did you get the la valve covers on the Magnum engine? And did you get those M/T valve covers from the guy with the demon?..
I learn something new all of the time... Thank you..i got them from Thadeous, he has a Demon too, not from Paul though. They just bolt direct on, but i stead of 10 studs it’s only 5.
i’m still waiting for my rear frame rails, but it looks like i’ll might won’t have room for the seat! i want to move rear wheels a little forward(10inches probably) if i’ll go with ladder bars. i don’t know, have to mock up to seeladder bars with either diagonal locator or panhard bar and coilovers for me. much more positive location.
neil.
