You should pull the rods out of it, and send them to the machine shop to be resized. If you don't, it won't be long before the new rod bearings look just like the ones in the pics. Not trying to spend your money for you, but I learned that lesson the hard way many moons ago. :banghead:
That's cool that you asked your little sister to help.rayer: The rods are factory stamped IIRC. The cap and the rod should have corresponding numbers stamped on them, and should be put together so the numbers are on the same side. Make sense?
I know all of that but what I'm saying is the rod and the rod cap have previous stamps by the origianl owner and none of the numbers match lol. I pulled #7 out of #1 cylinder.
:burnout:Keep rollng,D.R.....
keep up the good work but get rid of that ugly hei and put a mopar distributor in it.
:burnout:
I never give up!
I was looking at my radiator last night. I think my uncle and I are going to build a custome front radiator support with the same material we used to build the fuel cell cradle. My problem is my radiator is too thick for the stock position, therefore I can't put a fan on the inside (puller). So were going to cut out the old radiator support and make one so the radiator sits in closer to the grille. Anyone have ideas?
cut the radiator frame open to the width of your radiator drop it down from above,, if you remove the top of the support u can dron the radiator down in,,,to position,,then make a new support to go around the radistor from side to side,,, if you dont the fenders tend to lean in ward,,,make sure you have clearance for the hood linkage,,
i can drawl it out i meen i have no clue how to drawl it on here,,,,,,, let me know what you come up with,,,,its all going to depend on how thick and the type of mounting flange is on your radiator,,,
Well I was wrong. The distributor came today. It looks pretty good for what I paid for it. Now I'm having second thoughts because of fitment between the firewall and intake manifold runner...
thats way over kill from what i was trying to say,,but if its in your budget,,go for it,,,but all that is not needed,,for a street car good luck
Run this.... As long as it fits correctly, good to go. Watch the module,my.02..... A great choice,if it fits correctly. (Check everything, here.does it engage with the oil pump shaft,correctly?) Most aftermarket speed parts,sometimes" just doesn't, bolt in"....
I went out and bought all the tubing to do it this way. I'm hoping this sunday I get to build it. If I'm going to customize something, I'm just going to go all the way lol.
This one actually wan't bad. I put everything together just as a mock up. The dizzy dropped nicely into the oiling rod groove, it cleared the rear intake runner, and I believe i have more than enough room between the firewall.
