How I feel about mine but worse no console wanna check the kid that did this!
well we all, we all make mistakes lol!
Yeah yours looks pro just a change in direction hahaha mine it's ok it's pretty bad interlock not connected locks keys in column after you drive it's a feature...wonder if they option thatwell we all, we all make mistakes lol!
Great work Don!I am nearly ready to start the engine assembly. Even though the block is fresh from the machine shop and clean, i still thoroughly cleaned the exterior of the block, dried it and painted it red to match the oil pan, timing chain cover and several small parts that Leanna powdercoated for me a long time ago! I’ll bag it until i get the crank back from the machine shop. The crank is the original 66 4 speed forged unit. Machine shop guy is going to open the crank pocket up to accept the A500’s torque converter.
I cleaned and painted the Holley Street Dominator intake manifold, i went ahead and installed a NOS 5/8ths heater hose fitting, the Sniper temperature sending unit, the Dakota Digital temperature sending unit, the vacuum tee and 4 carb studs.
The NOS water pump got the cleaning treatment and a coat of red paint. it has an 8 blade impeller - does that mean Heavy Duty or maybe for AC? I also installed a NOS 5/8 heater hose fitting, a 1 inch 70/up bypass hose fitting to match the one on the intake manifold and another plug.
Both heads have been rebuilt with new valves, hardened exhaust valve seats and guides as needed. It was also cleaned and painted red (just one head pictured)
I will also paint all the mounting bolts separately and I might give the complete assembled engine a once over of paint depending on what it looks like after assembly.
Great work! Nobody will ever know it's even there.Working on a little project today - installing the distributor HEI adapter. I bought this adapter from the website designed2drive.com. As the website explains, this adapter (the yellow dichromate part) installs under the vacuum canister and the 4 terminal HEI mounts to the adapter. It only installs one way so The installation was pretty straightforward. I used an old plug I had along with the provided terminals and heat shrink to install the plugs on the HEI module to the electronic distributor. The other 2 HEI terminals go to the positive and negative of the coil, eliminating the ballast resistor.
Your the man Don! You figure out new solution in way no other can keep up with. Hats off!Since I’m trying to keep the engine compartment looking reasonably close to stock, the plan is to keep the ballast resistor but remove the resistor and replace it with a just a wire. After removing the mounting bracket from the case (which I will send out to be refinished in the original yellow dichromate), i cut the resistor from the terminals, got them removed and wire brushed cleaned. I soldered a 12 gauge wire to each terminal and reinstalled to the housing. Once I get the clamp back, I can install the new and improved (for my use) to the upper firewall and it will still look stock!
So, will that adapter add heat to the distributor? Is it necessary for the HEI system?
Great work Don!Another project completed today - the radiator. At least 20-25 years ago I had the radiator shop replace the 2 core (which pretty bad) with a 3 core. It was time to dig it out and use it in my Dart wagon conversion. It’s just the core and top and bottom tanks as I didn’t have any 65/66 side panels correct for the fan shroud
I couldn’t remember from where or what The radiator came from. I found a website that listed radiator by number, year and application. According to the information this 22 inch radiator came from a 67 Barracuda. As I’m not particularly a matching numbers guy, this radiator will work just fine.
As I now have the correct side panels for the early A fan shroud, time to clean them up and solder them to the core.
Then a coat of high temp black paint top to bottom side to side
Because my A500 transmission uses 3/8th lines rather than 5/16ths, i ordered the 1/8NPT male and 3/8th male flair for the cooler lines and installed them.
Per the FSM the 65 used a 16PSI radiator cap. A new one from Rock Auto takes care of that
I pulled from storage my previously powdercoated fan shroud brackets with captive fastens that install in the side brackets
And my hard-to-find 65/66 fan shroud. I need to clean it up and repaint it. I won’t install it until after the motor, fan and radiator is installed. It being a 2 piece shroud will make it easy (easier) to install!
Speedy recovery!I will be out of commission for awhile; i had a hip replacement on Thursday and with help from my youngest son, his nurse GF, i was finally able to get to the kitchen table.
Hope far a fast recovery Don!I will be out of commission for awhile; i had a hip replacement on Thursday and with help from my youngest son, his nurse GF, i was finally able to get to the kitchen table.
