67 Cuda Notchback Hell Cat Swap
New Hemi Engine Swaps
  1. Chuckbizkits
    Chuckbizkits Well-Known Member
    504
    648
    Sep 18, 2007
    North Orange County, CA
    Local Time:
    9:56 AM
    Rear end assembled.
    • Like Like x 12
    • Chuckbizkits
      504
      648
      Sep 18, 2007
      Local Time:
      9:56 AM
      Installed the Quick Performance rear end before it got too hot. Gertz supplied the suspension.
      • Like Like x 6
      • Chuckbizkits
        504
        648
        Sep 18, 2007
        Local Time:
        9:56 AM
        Finished the paint work on the engine compartment and firewall. Installed the engine, hopefully for the last time.
        • Like Like x 12
        • A56
          A56 MoParAffliction
          4,455
          9660
          Jun 24, 2014
          South of the Mason-Dixon Line
          Local Time:
          8:56 AM
          • Agree Agree x 3
          • MrJLR
            MrJLR Built, not bought FABO Gold Member
            5,107
            5369
            May 14, 2015
            Chino, California
            Local Time:
            7:56 AM
            One word..... awesome!
            • Agree Agree x 1
            • 408 swinger
              408 swinger FABO Gold Member FABO Gold Member
              2,335
              2170
              Nov 12, 2010
              Iowa
              Local Time:
              9:56 AM
              Hell, yeah!
              • Like Like x 1
              • Chuckbizkits
                504
                648
                Sep 18, 2007
                Local Time:
                9:56 AM
                Installed the factory oil cooler and lines. Started on the front suspension.
                The lines in the back are for the blower cooler and reservoir.
                • Like Like x 4
                • Chuckbizkits
                  504
                  648
                  Sep 18, 2007
                  Local Time:
                  9:56 AM
                  • Like Like x 6
                  • Chuckbizkits
                    504
                    648
                    Sep 18, 2007
                    Local Time:
                    9:56 AM
                    Working on the ride height. Had to order 2" drop spindles.
                    • Like Like x 14
                    • MileHighDart
                      MileHighDart Well-Known Member
                      4,469
                      4179
                      Jun 3, 2004
                      Lyons, CO
                      Local Time:
                      3:56 PM
                      Wow ! Amazing build
                      • Agree Agree x 1
                      • Hellcat Cuda
                        Hellcat Cuda Well-Known Member
                        587
                        74
                        Jan 12, 2013
                        Northern Calif.
                        Local Time:
                        7:56 AM
                        Great progress. She's lookin' REAL GOOD!
                        Just in case you're not aware, the Hellcat (cars) have an initial heat exchanger (for the blower coolant) on the driver side, about the size of this oil cooler, and then a primary heat exchanger in front of the radiator, about the size a an AC condenser. At one time I was going to use all factory parts, but I've decided to find good quality aftermarket stuff that will fit my car as precisely as possible and have the inlets/outlets where I need them.
                      • isharj
                        isharj Member
                        12
                        1
                        Sep 2, 2015
                        Texas
                        Local Time:
                        9:56 AM
                        Did you custom make that hood or is it available to purchase?
                      • Chuckbizkits
                        504
                        648
                        Sep 18, 2007
                        Local Time:
                        9:56 AM
                      • isharj
                        isharj Member
                        12
                        1
                        Sep 2, 2015
                        Texas
                        Local Time:
                        9:56 AM
                        Did you glass in the 4 rear vents on the hood? Can't quite tell from the pic.
                      • Chuckbizkits
                        504
                        648
                        Sep 18, 2007
                        Local Time:
                        9:56 AM
                        No vents. I think I'll cut out the front.
                      • isharj
                        isharj Member
                        12
                        1
                        Sep 2, 2015
                        Texas
                        Local Time:
                        9:56 AM
                        Gotcha. The AAR style on VFNs site shows to be cut open in the front and then the 4 vents at the top rear to be cut out already as well. Did you get yours without the openings?
                      • TT5.9mag
                        TT5.9mag Two atmospheres are better than one
                        990
                        943
                        May 5, 2016
                        So cal
                        Local Time:
                        7:56 AM
                        Wow you do such nice work. And close by. Do you have a shop in Orange County or is this at your home?
                      • Chuckbizkits
                        504
                        648
                        Sep 18, 2007
                        Local Time:
                        9:56 AM
                        Thanks! My house. Yorba Linda.
                      • TT5.9mag
                        990
                        943
                        May 5, 2016
                        So cal
                        Local Time:
                        7:56 AM
                        Oh you’re closer than I thought. I’m in norco. I would love to see this car when it’s finished. Maybe we could meet up.
                      • Chuckbizkits
                        504
                        648
                        Sep 18, 2007
                        Local Time:
                        9:56 AM
                        I work in Norco!
                      • TT5.9mag
                        990
                        943
                        May 5, 2016
                        So cal
                        Local Time:
                        7:56 AM
                        Small world. What do you do in norco?
                      • MrJLR
                        5,107
                        5369
                        May 14, 2015
                        Chino, California
                        Local Time:
                        7:56 AM
                        I live in Chino!
                        • Like Like x 1
                        • Turbo440Dart
                          Turbo440Dart crank runner over-er
                          49
                          11
                          Aug 31, 2020
                          Norco Ca
                          Local Time:
                          7:56 AM
                          Little late for me here, just moved to Norco about 4 months ago. Haven't seen really any mopars around.
                          • Like Like x 1
