Wylde1
"No Value Added" Member
and man may I say this is an Awesome thread to be subscribed too
Mad makes everything look easy. :thumblef: :thumbrig:
Wylde1.
This was an as built project. I cycled the suspension and the geometry is perfect. No binding etc and it will go REAL LOW, Low Rider Low, anybody got a block of magnesium so I can throw some rainbow sparks?? haaaaaa:-D
I have not calculated the Anti Squat. Reason being this in not a full tube chassis car and the links are alot shorter. On a regular link set up you have SEVERAL holes for adjustment that would help the DRAG RACER fine tune the system. This set up here is more of a Weekend Street/Strip set up. Not a FULL RACE DEAL.
I had the pinion set at 0 during mock up and when I cycled the suspension 5" each way up or down it holds the pinion angle dead on 0. So after the drive train is installed I will get the correct pinion angle per the output shaft of the trans and set it from there. It should stay dead on where ever I set it at through all of the suspension travel.
Cut tight to the tub from the tub cut/floor intersection point until you are moving parallel to the vehicle centerline, then move it over to the rail. That will leave you plenty of material to make that radius cut at each end. It's a little more work from a cutting standpoint, but, the end result will be nicer.
I would wait to cut the inner fender spots until you get the tub out.
Hey those cardboard patches look awfuly close LOL.Here,s how mine looked when done.Before and after welding.
It took me about 24 hrs,working in 5-6hr incriments after my 10hr day job.By the looks of your skills,you should be done quicker.Just a couple more pics to give you some ideas.Good luck!How many hours did it take you on yours? Did you weld BOTH sides of it? It is quite a bit of work no doubt. I have been playing a cartoon in my mind for days and my finished product should come out good! haaaaa:toothy10:
Why did you do the z cut? And are you planning to welt it to the frame rails?
Great work so far!
The Z Cut is so I don't loose the Seat Bracket. I just cut around it, the strip of metal will stop and start there is all. Most Mini Tubs do this to leave the seat belt hardware in tact. Mine fell in the radius so I just need to move it about an inch. Stay tuned you will see what I am talking about in a few days or less hopefully.
Looking good,only 22 hours left!LOLYou,ll probably knock it off alot quicker than I did.Was the first time welding in 20-odd years,enjoyed every minute of it.:clock:
