—-car is looking great. did those 90' exhaust bends come with the hanger rods or did you add them? i like the collector flange on the mufflers
What I used was a 180 mandrel bend tube. I cut it at 60 degrees from each end. I got the rubber isolators from the parts store and fabricated / welded brackets to the pipes. Stud through the frame to hold it at the top. Tips are 304 stainless that I shortened / welded. I always add collector flanges on the ends of the mufflers, looks cool and makes things easy.
