mygasser
I'll be adding a catch of some kind mate when I alter the new ones.
yes, the block, heads and crank will all go in the machine shop's 'dishwasher' while they've got them. the small parts i'll do myself.that puppy needs a good steam bath
the s/six and box are being collected wednesday evening so i can clear up all the anti freeze and trans fluid in the garage View attachment 1715212982
then i've decided to mock up the 383/727 (make mounts etc) before i pull them apart for a freshen up, i'm not fitting the torque convertor either for this. reason is if i fit it all in i KNOW i'll just get it going and use it as is. i want to paint the engine bay and the engine/box so this way i have to take them back out and they'll get what they need before the final fit up.
well it makes sense to me anyway View attachment 1715212983
neil.
Slant k member makes it easy, you'll need to cut n box the front of the drivers side mount tower to clear the oil pump, bolt hole stays same....then make a tower and or bracket for the passenger side "doing all the mock up with motor and trans in car and trans bolted up to mount.
The center section/trans mount of the torsion bar anchor is removable, 4 bolts n nuts.
Yeah thanks, I will be getting that done. I'm going to bring some poly bushes etc home from work to make it up.I'd put a torque strap from that left side of the engine to the K frame, otherwise you might rip that mount loose in short order. A buddy of mine had a 383 69 charger, it ate left motor mounts until he used a length of chain on the left side of the engine and attached it to the K frame. Prior to that he dented his hood (bonnet) from the underside, and bent the **** out of the air cleaner when the first one let loose.
cheers, it works for me matenice torque bar. good idea to just weld the bracket to the k-member
