You mention using 30wt for break-in. What do you plan on running afterwards? Also, what brand?
So the engine as it sits now.I’ll have to spend an hour and reread everything to find engine details. This is why I kinda break my projects down into sections.
Well I was going to run vr1 because it's available locally 10-30 and we'll see because Tim thinks it's going to kill power. I don't think so but we'll see.You mention using 30wt for break-in. What do you plan on running afterwards? Also, what brand?
Yea we know. lolWell I was going to run vr1 because it's available locally 10-30 and we'll see because Tim thinks it's going to kill power. I don't think so but we'll see.
Yes, he'd recommend that exactly but he isn't paying for it.Yea we know. lol
I bet he's trying to get you to use Torco products.
Nothing but VR1 for me. Besides, I already have 5 jugs of it.... lolWell I was going to run vr1 because it's available locally 10-30 and we'll see because Tim thinks it's going to kill power. I don't think so but we'll see.
Yeah, the stuff works and works very well.Nothing but VR1 for me. Besides, I already have 5 jugs of it.... lol
He's out there on some.But I will say, I trust Tim's opinion most of the time.
Yep me tooHe's out there on some.
Im sorry to hear that man, but I’m glad you are on the upswing and staying positive.Also, I think my tiny family of wife, cats and dogs are on the upswing. 3 crap things happened back to back to back.
Pup was hit by the truck, amputated leg ( she is doing great. My wife broke a rib last week and I somehow released my little kid chicken pox bs out as adult bs worse as shingles and I'm only 45 . But besides being in massive pain and same with my wife were helping each other out and are grateful.
Thanks Jared.Im sorry to hear that man, but I’m glad you are on the upswing and staying positive.
I should have remembered to post that both afrs worked the last couple pulls.Do you have a stand alone o2 you can beg, borrow or steal? Place it in the side that isn't working and then swap sides with the dyno o2. O2's offen times won't read the same from side to side but should read the same on each side with a no change test. Also low rpm readings with an o2 can sometimes be inaccurate.
Do a couple of no change pulls or just partial pulls if the tune doesn't look right. This might give you either more or less confidence in the readings you're getting now. Not having confidence in the data you need to help you tune makes it tough. Especially on a "new to you" system you're still sorting out.
If you have good fuel flow data and air flow data you should have an air fuel ratio channel to compare to your o2 readings. The numbers might not be exactly the same but they should trend in the same direction ( at higher rpms).
Remember that your o2 reading even if accurate is just an average of four individual cylinders in a collector. And based on the position of the o2 it can be influenced by one cylinder more than another. Also air fuel ratio as calculated by an air flow meter and fuel flow meter is going to be an average of all 8 cylinders.
Spark plug reading, individual EGT temps or individual o2 readings can help sort things out on a individual cylinder bases.
I'm interested in how you are using the oscilloscope on the dyno. I used one years ago when doing tune-ups but haven't used one on the dyno. Are you using it durring a pull or under load?
In my opinion the reversion at low speed can sometimes make the o2 reading unreliable. I don’t know that as fact. This can be affected by the length of pipe behind the o2 sensor too. I see lean spikes in the o2 curve at lower rpms that don't coincide with the air fuel ratio as calculated by the airflow and fuel flow meters. There could also be others reasons for that too.I should have remembered to post that both afrs worked the last couple pulls.
You make some points that made me think.
We have a 6inch exhaust system that lays on the ground with big semi tractor mufflers on the end.
There's so much exhaust pulse reversion coming back out of that pipe that's hooked to my collectors so there's air definitely getting backed up and the point of the 02 sensor
This is from Jere Stahl's (of stahl headers) website. I don’t know if the site still exist. There was lots of helpful information about dynoing on his site. I copied it into my dyno book when researchinghow to build my dyno. Here is what he had to say about dyno exhaust. For what it's worth.I should have remembered to post that both afrs worked the last couple pulls.
Wow, that is interesting and I'll pass this along to Tim because we've just been using 6 inch pipe, 12 foot long with 48 ×6 inch mufflers at the end with a slight bend from collectors to the ground which is about 2 feetThis is from Jere Stahl's (of stahl headers) website. I don’t know if the site still exist. There was lots of helpful information about dynoing on his site. I copied it into my dyno book when researchinghow to build my dyno. Here is what he had to say about dyno exhaust. For what it's worth.
Yes they definitely are. I will be running afr in car also so I can hopefully record data at some point.In my opinion the reversion at low speed can sometimes make the o2 reading unreliable. I don’t know that as fact. This can be affected by the length of pipe behind the o2 sensor too. I see lean spikes in the o2 curve at lower rpms that don't coincide with the air fuel ratio as calculated by the airflow and fuel flow meters. There could also be others reasons for that too.
All that said about how unreliable o2s can be I have found them to be very helpful (a real time saver) and for the majority of the time a reliable indicator of the air fuel ratio.
I'm not saying what you're doing is wrong I'm just presenting what Jere had to say about it.Wow, that is interesting and I'll pass this along to Tim because we've just been using 6 inch pipe, 12 foot long with 48 ×6 inch mufflers at the end with a slight bend from collectors to the ground which is about 2 feet
