Yes, and it’s currently degreed in with 4° advance; 110 ICL.Do you have a degree wheel? Would utilize the power of the cam better.
Oh okay wasn't sure if you did. Should be able to pull 6500 pretty easy and have a good power band curve.Yes, and it’s currently degreed in with 4° advance; 110 ICL.
Ouch.Finished assembling the motor today. It’s my first time assembling a roller motor. I hope this thin metal thingy isn’t important…
Oh I definitely forgot it, but I already pulled the intake to get it back home.I hope you are kidding about that spider if running OEM style lifters and dogbones. It's REALLY important with oem rollers
I drilled and tapped a hole also. Just ran the boost controller/adjuster straight off that.I’ll just be running off the wastegate spring for now, but will switch to a ball/spring boost controller when I want to turn it up. They bring boost in much harder so I’ll have to see how the tires handle it.
It did not have a hole so I tapped the back side of the compressor housing for a 1/8npt nipple. When I switch to the ball spring valve I’ll use manifold pressure.
