autopar3000
Geez, that first picture looks like a valve body!
What do you guys think?
Picking out my Gauges from SpeedHut for my 72 Swinger.
CAN-Bus for Tach, Volt, Water Temp and probably Speedometer.
Senders for Fuel Llv and Oil pressure.
~$900 total for the gauges & panel.
The speedometer is setup for Turn signal and High-Beam indicator which I forgot about needing to integrate with an aftermarket setup.
Here are the pictures. If you use the blue ferrules, make sure to get the 6 way crimper. I have one that crimps them square..... square pegs don't fit in round holes....... I borrowed one to get the proper crimp this way it crimps on six sides making it semi round and they fit much better
Do you have a part number for these blue ferrules? Or are the blue ferrules all the same size?
Thanks. I ended up buying these and will see how they work.
Is this the same engine that would be in a 2011/2012 or so Jeep Wrangler ?
I don't think he has much choice on manifolds since the manifold and head are cast as one pieceI like the thinking all the way around.
What exhaust manifolds are you planning on?
