Grnfsh
Member
MD360, any updates on your progress with AlfaOBD?
Yeah It was a Bust. It will do all sorts of cool things for the Delphi sourced TIPM in the Darts, Renegades and 200s but doesn't offer much for the Motorolla TIPM I have from a 2013 Wrangler.MD360, any updates on your progress with AlfaOBD?
Finally got it fired up tonight. Cobbled up a fuel system and filled the engine up with water and oil and she started instantly.
The rack and pinion conversion is really getting complicated. There's just too much other work to be done to try and tackle it too. So I'm going to bypass the AC and avoid that hassle.
Luckily I think I found a factory A/C delete bracket, part number 4627207AB (~$40)
This pic shows the interference and the circled bolts is were the new bracket should mount.
View attachment 1715109205View attachment 1715109206
That's what I say too, every time I drive through NW Ohio. lol. Still better than Gary, IN, tho. haha.Wish I wasn't in NW Ohio....
The engine mounting brackets($30each) part numbers are
68161224AB-BRACKET-ENGINE MOUNT
68089045AA-BRACKET-ENGINE MOUNT
They're for a 2014 Ram 1500.
They're the only type of 3.6 mount that wasn't a giant cast iron/rubber beast. They offer greater versatility and i just have to then built UP to them with new frame brackets and insulators/bushings.
BEEP !
That aircon compressor may well be a problem for us. It may not clear the Dodge truck LHS chassis rail … and that will be a bummer.
Thanks again for your research info.
Jim
