Yes, the turbo housing hits. 4” downpipe on this new one. Gonna be fun! Yes, hot side is “divided” to the flange but was less important on the previous turbo because it was an open T4. The new one is a divided T4 and I’d like to keep it fully divided.It’s the turbine housing that hits? Is the downpipe flange also a different size? Thats going to be a big job. Is your hot side plumbing 2 separate ports?
Any issues with heat down there? Mine are mounted in the same spot and I’m about to install a heat shield between them and the manifolds. The coils start to misfire on longer drives.I have my coils mounted to the “belly” of the block on each side where the truck motor mounts would bolt on. Works great for me and gives plenty of room for the downpipe at the valve cover. Only thing is now it’s a pain to pull the valve cover without unbolting the downpipe.
I’ve thought about that but I have the block hugger header and the hot side pipe that travels in that same area.I have my coils mounted to the “belly” of the block on each side where the truck motor mounts would bolt on. Works great for me and gives plenty of room for the downpipe at the valve cover. Only thing is now it’s a pain to pull the valve cover without unbolting the downpipe.
I can’t say I recommend it. I did it for looks alone, and they’ve been a pain. I’ll likely end up mounting them on the valve covers like yours.I’ve thought about that but I have the block hugger header and the hot side pipe that travels in that same area.
That’s the idea. I have the room since I went to coilover suspension and got rid of the torsion bars. Probably not 4” to the back bumper. Just something like header length for now to the torsion bar crossmember.Any chance you’re going to try and route a full 4” downpipe while you’re at it?
That cover is nice. They want $200 for it though. What’s the gain using it?My downpipe is much further over, and allows acceptable access to the plugs. Having it that far over was also helpful for downpipe routing. A couple pie cuts could get yours a little further from the valve cover.
Fyi, the turbine housing on your new turbo is the same footprint as the bigger Vs racing turbos in case you might ever upgrade. So a S480 80/88 t4 1.25 will bolt up to your new up and down pipe. The compressor housing is a bit bigger though so you could clearance for that now as well to future proof. It seems like the 5.3ls guys are spooling those almost as fast as a 78/75 as long as they utilize the twin scroll.
Here’s a pic of the gen 3 78/75 compressor housing I’m running vs the housing you have now. It’s also the same size as a s480 so you can see the size difference.
Awesome!! I forgot you went to coilovers. Even more excited to see your back pressure numbers now!That’s the idea. I have the room since I went to coilover suspension and got rid of the torsion bars. Probably not 4” to the back bumper. Just something like header length for now to the torsion bar crossmember.
He told me it was worth a little more power, but I honestly only upgraded for the sound. The gen 2.5 was inaudible on my car, and I do love turbo noisesThat cover is nice. They want $200 for it though. What’s the gain using it?
So far no. And I’ve driven roughly 2hrs non stop with stop and go traffic.Any issues with heat down there? Mine are mounted in the same spot and I’m about to install a heat shield between them and the manifolds. The coils start to misfire on longer drives.
More digital dash progress. Made some alum mounts to fit in the stock dash locations and where my hardware will be mounted. Still aways to go.
These Early A bodies don’t have the luxury of extra under hood space like you guys.Damn I didn’t realize you had to get that far into it! Looking good
Hey had to cut out part of my inner fenders lol Are you going to dump your waste gate to atmosphere now or plumb it back into the exhaust like before?These Early A bodies don’t have the luxury of extra under hood space like you guys.![]()
I might try both just to see how back pressure responds. Got a new WG to add to the mix also. Thinking about controlling boost with dome pressure at some point in the future.Hey had to cut out part of my inner fenders lol Are you going to dump your waste gate to atmosphere now or plumb it back into the exhaust like before?
45mm? Wow going CO2 pressure for boost control niceI might try both just to see how back pressure responds. Got a new WG to add to the mix also. Thinking about controlling boost with dome pressure at some point in the future.
50mm. Yeah I like the idea of being able to control boost from the lightest spring pressure to infinity.45mm? Wow going CO2 pressure for boost control nice
