1. moparmandan
    moparmandan FABO Gold Member FABO Gold Member
    2,714
    2613
    Jun 28, 2017
    Deland, FL
    Local Time:
    8:25 AM
    Yes, and my son did have to use 1/4 spacers on his Scamp. He really wanted to stay with his Cragar SS wheels.
    • Thanks! Thanks! x 1
    • moparmandan
      2,714
      2613
      Jun 28, 2017
      Deland, FL
      Local Time:
      8:25 AM
      Never had a problem with pinion angle after a spring change myself. Replacing worn out springs with new ones will likely correct things father time has changed!
      • moparmandan
        2,714
        2613
        Jun 28, 2017
        Deland, FL
        Local Time:
        8:25 AM
        Mostly ready to install. Used rattle can flat black cause its what I have a lot of. This one needed axle seals, axles, calipers, rotors and pads. No driveshaft work since its replacing an 8.25. Still a deal!
        20200402_191756.jpg 20200402_191807.jpg 20200402_191618.jpg 20200402_191609.jpg 20200402_191555.jpg 20200402_191513.jpg 20200402_191505.jpg 20200402_191450.jpg
        • Like Like x 3
        • moparmat2000
          moparmat2000 FABO Gold Member FABO Gold Member
          19,058
          8020
          May 13, 2010
          Grand Tetons
          Local Time:
          7:25 AM
          Moparmandan did you ever get the PM I sent you?
        • moparmandan
          2,714
          2613
          Jun 28, 2017
          Deland, FL
          Local Time:
          8:25 AM
          Let's me check.
        • moparmandan
          2,714
          2613
          Jun 28, 2017
          Deland, FL
          Local Time:
          8:25 AM
          Yup! :thumbsup:
        • moparmat2000
          19,058
          8020
          May 13, 2010
          Grand Tetons
          Local Time:
          7:25 AM
          Moparmandan I sent you another PM.
        • dartfreak75
          dartfreak75 Restore it, Dont part it! FABO Gold Member
          9,916
          7561
          Aug 10, 2011
          Virginia
          Local Time:
          8:25 AM
          • dartfreak75
            9,916
            7561
            Aug 10, 2011
            Virginia
            Local Time:
            8:25 AM
            What gear oil are yall using in your 8.8? Iv read multiple answers online.
          • moparmat2000
            19,058
            8020
            May 13, 2010
            Grand Tetons
            Local Time:
            7:25 AM
            I would use the stock weight gear oil it calls for and limited slip additive. (Friction modifier) if you have a limited slip.
            • moparmat2000
              19,058
              8020
              May 13, 2010
              Grand Tetons
              Local Time:
              7:25 AM
              Being it's a stock rear end, using something different than what ford calls out as far as oil weight and type may ruin it. Friction modifier on the other hand anything aftermarket is just fine. Mine is from Yukon gear, but GM positraction additives the same stuff.
              Without it, just turning a corner you will get this bump, bump, bump feeling. That is the clutches in the differential gripping, binding, and releasing multiple times. Friction modifier additive stops that and allows the smooth slippage for turning corners, but full grip when they are needed to grip.
              Do NOT get this on your hands. This is stinky assed shit. It will take a week of washing to wear it off. Latex gloves are definitely required. I have to soak the new clutches I have in this stuff before assembling the diff. My shop is gonna stink like shit lol.
              • dartfreak75
                9,916
                7561
                Aug 10, 2011
                Virginia
                Local Time:
                8:25 AM
                So put a new bottle of friction modifier in it even if it's already in the gear oil ?
              • moparmat2000
                19,058
                8020
                May 13, 2010
                Grand Tetons
                Local Time:
                7:25 AM
                Gear oil normally doesnt come with friction modifier. I add a half a bottle of gear oil to the diff, then put the friction modifier in the bottle of gear oil with the rest of the gear oil, shake the shit out of it, to mix it, then pour it in the rear.
                • dartfreak75
                  9,916
                  7561
                  Aug 10, 2011
                  Virginia
                  Local Time:
                  8:25 AM
                  Least of my worries now lol:BangHead:
                • moparmandan
                  2,714
                  2613
                  Jun 28, 2017
                  Deland, FL
                  Local Time:
                  8:25 AM
                  Rut ro raggy.
                • dartfreak75
                  9,916
                  7561
                  Aug 10, 2011
                  Virginia
                  Local Time:
                  8:25 AM
                  What diff cover seal do yall prefer? I found a cork one for like 8 bucks but they have the rubber coated steel one for 30 something? The rubber one looks like it would seal better but the 8 dollar one is tempting
                • jrlegacy23
                  jrlegacy23 68 Barracuda
                  2,597
                  262
                  Jun 27, 2006
                  Laurens, NY
                  Local Time:
                  8:25 AM
                  I have used RTV and I have used this one:
                  Lube Locker Ford 8.8" Differential Gasket
                  • Like Like x 1
                  • dartfreak75
                    9,916
                    7561
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    8:25 AM
                    Yes that is the one I found it's a little cheaper there. Would you still have to use RTV since the gasket has the rubber coating?
                  • jrlegacy23
                    2,597
                    262
                    Jun 27, 2006
                    Laurens, NY
                    Local Time:
                    8:25 AM
                    No RTV if you use that gasket. And that one is reusable also.
                    • dartfreak75
                      9,916
                      7561
                      Aug 10, 2011
                      Virginia
                      Local Time:
                      8:25 AM
                      Thanks I think it would be worth the extra price of not having to deal with the rtv I always make a mess of that crap
                    • dartfreak75
                      9,916
                      7561
                      Aug 10, 2011
                      Virginia
                      Local Time:
                      8:25 AM
                      Ok another question maybe I'm a little dumb tonight but for the life of me I cant figure out the brake lines on the rearend I know the right hose has the metal line that connects to the left hose does the metal line coming from the master cylinder go in the left has as well? Or is there another hose that goes from the main line to the left hose ?
                    • moparmandan
                      2,714
                      2613
                      Jun 28, 2017
                      Deland, FL
                      Local Time:
                      8:25 AM
                      Another rubber line. Look right up there ^^^^^^ Post #853
                      • moparmandan
                        2,714
                        2613
                        Jun 28, 2017
                        Deland, FL
                        Local Time:
                        8:25 AM
                        Did you weld the mounts on when I reminded you?
                        • Like Like x 1
                        • jrlegacy23
                          2,597
                          262
                          Jun 27, 2006
                          Laurens, NY
                          Local Time:
                          8:25 AM
                          The one steel line comes back from the master and goes into a rubber line above the rear axle. That rubber line goes down to the axle and slits with a T or Y fitting and runs to each rear wheel.
                          • dartfreak75
                            9,916
                            7561
                            Aug 10, 2011
                            Virginia
                            Local Time:
                            8:25 AM
                            Not yet I haven't welded anything I'm out of wire haha
