Miranthis
I have read the engine removal thread for 273 V8 and manual trans. here ( Engine Removal ). I have a 66 Barracuda with stock 273 4bbl and A-833 and it is being disassembled so hood is off, radiator our, fenders off, etc. I am doing an "out the top" removal as we have to have it rolling until the rotisserie is ready and we can get it over to the body shop. Is it as 'simple as removing the carb, distributor and the bell housing bolts and then prying it apart (of course after the two motor mounts are disconnected)? How many bolts am i looking at for the bell housing? Does the starter need to come off first? The clutch tube is attached to the bell housing and frame so that comes off later, correct? Should I block the front of the trans or let it flop?
Any other tips for removal?
