RAMM
They are small Hedman 1 5/8 truck headers. I said I was going to try straight av gas not the current 25% pump 75% av gas.What did the final flow numbers look like?
And, what are the cams specs?
240 psi...... I wouldn’t be brave enough to try and run that on straight pump gas.
The current headers are 1-3/4x3?
Flow numbers are what they were earlier in this thread 260-265 at most. Cam is a reground comp roller, 254/260 . The report is also in this thread. J.Rob
