you'd be wrong.
I don't think you'd need to spin it 8k to make 500 hp, probably more like 7500 at most maybe less if you did a good job with the combo, but ya you'd probably be shifting and crossing the finish line up there.
you'd be wrong.
Do you have a 500hp recipe for a 318 at 6200-7000 rpm
IF the combo is set up to make HP "up there"..... IF not, then power drops off and the car slows up. I've played "shifting" games at the strip, and there is a happy spot for every engine. Can you spin it more??? Yep! I spun a 340 7200 RPM's and slowed up a 1/2 second vs 6000 rpms. It's wherever the power band is set up to run. BUT, you don't NEED 8500 rpm's to run 9's. To many of them doing it at 6500- 7k.
Make this your statement under your Avatar...That, is the definition of RETARDED.
To get out of the minds "318 vs ***", lets look at a single cubic inch. 360 per say. Some build them to shift at 7200 rpms all day and do it going 11's in the 1/4. Some build them and shift at mid 6k and run mid 9's. Why would that be?? Because it's about how well the heads are flowing, and a cam to match, and a intake/carb to sit on top of it that compliments the design of the build. I bet my 318 makes more power at 5000 rpms than a stock '73 340, and I have less of just about everything. Why would my smaller engine make as much or more power at the same rpm??? Is it my smaller valves? Or less compression? I don't say this sarcastically, I say it because there is a theory that one HAS to spin the daylights out of the smaller engine to make equal power. Simply not the truth.
And save the transmission. I threw away a lock up 904. You can get mild performance lock up converters for them and pick up a little mileage along the way.Got a line on another 318 Roller Engine, may have to go check this out this weekend.
I don’t see anyone saying it can’t be done.
I think what it boils down to is..... when it comes to actually laying down your $$$ and building it......it would appear(by the shear lack of abundant 500hp 318 builds) that most people opt to get those extra hp that you get from the added cubes....... and not spending any more for it.
It’s just economics.
Same reason 440’s are more popular than 413’s, and 400’s are more sought after than 361’s.
I’d love to see someone step up and do a legit, dyno tested/verified 500hp build with a stock stroke 318.
Show everyone exactly what it takes.
The fairly high effort enginemasters build came up 23hp shy.
Who are you trying to kid. If you think an engine is just an Air Pump then by your own definition the only way to increase HP per CI is through Volumetric Efficiency.
Throwing parts at an engine will only get you so far.......
I didn't know it was April Fools Day. Shoot, if it's not moving air, let's plug the carb and exhaust - stuff some rags in there. Shouldn't effect HP at all, after all, we know air flow doesn't matter
Did you know a 318 with a 4bbl, ported heads, 340 cam and headers will flow more air at 5000 rpms than a 318 2bbl that's 100% stock???? Hmmmm.... same RPM but more flow.You did say this earlier did you not?
"I say it because there is a theory that one HAS to spin the daylights out of the smaller engine to make equal power. Simply not the truth."
So you're not gonna put more air through it but your gonna make more power how............
Cue everyone running “fast” shifting at 6200. It doesn’t change the fact that RPM makes horsepower.
Agreed.
You don't see them because they don't exist in nature outside of the local cruise night and usually the only proof is the owner's mouth. Show me a 500hp 318 on a dyno and I'll point out the lack of any belt driven accessories, hood clearance limitations, and a real exhaust. Aside from pushing the power band up, I think the stroke and bore size is more of a limitation than we think in terms of having good heads "available".
Spend some change and todays aftermarket support and 500 hp comes around pretty easy. Just not so easy for those working with a 2 dollar budget.. LOLAnyone who uses the dyno with dyno headers, ignition, carb and all that is wasting their time and money. If you are running a mechanical fuel pump you should be using that too, along with the alternator and water pump too.
With the heads available (the W2 has been around for decades and those heads will EASILY make 500 HP on a 318 or anything else) like the TF stuff that 500 HP is like oatmeal. It’s easy to do.
I'm looking forward to the recipe for a 500 hp 318 NA at 6200- 7000 rpm. lol and street friendly.
318 ? It will be hard enough with a 340 NA bellow 7000. imoI’ll post it up when my junk gets off the dyno.
