LOL... I think the closest will be the article with 477@ 6500 rpms.I've been waiting for someone to post up a basic recipe for a 500 hp 318 @ 6200 - 7000 rpm.
I hear it's easy.
I hear it's easy.
I hear it's easy.
The difference will be in the rpm, I don't care how you slice it , 1.54 hp per cube with a 323 will need rpm
I know your not saying this but I think hp/cid is where people get screwed up thinking it's hard for small engines to make power.
Just cause say 1.6 hp/cid is hard for a large engine doesn't necessarily mean the same for smaller engines, cylinder head is the main part for any desired hp level.
We know a fully ported /6 head can make about 300 hp so a 170 /6 making a 1.6 hp/cid for 260 hp isn't out of realm of possibility using nothing overly tricky than mainly reworked factory parts now a 543 stroker big block is gonna require a little more than a ported out 440 head to make 1.6 hp/cid for 870 hp and be a fully custom build.
There's a bunch of heads that can support 500hp in a 3.91-3.97 bore the only slightly tricky thing is getting the valve train to work at 7000-8000+ rpm.
And how do we know you're not just blowing wind up are wa- zoo...And yet some guys are doing it with stuff most say it cant be done with like stock heads.....
http://i151.photobucket.com/albums/s153/johnsmith_45/byronwheelstand.jpg
"I had a stock crank .04 overbored 360 in the Demon that went 10.25 at 129.99 mph. Ported 587 heads,.590 racer brown flat tappet cam, victor 340 intake, crane gold 1.6 rockers, 11.75 to 1 comp ratio. Motor in car now is a .04 over 360/ w a 4.100 stroke crank, [418 c.1.]. Still has the racer brown .590 cam and ported 587 heads, a little adtnl. work to heads, flat top piston out of the hole .080, 13 to 1 comp ratio, Victor 340 intake, Crane 1.6 rockers. Burns 110 octane race gas or would be fully streetable. Never over 190 degrees even when it's near 100 deg. outside. Has gone as fast as 9.68 at 135 mph and as far as 450 ft on the rear wheels. Definetly over 400 to 500 horse . Not to shabby for a junkyard headed small block in a car that weighs 3060lbs. I never recall seeing a brand X sm block w/ junkyard heads anywhere near my e.t. at or near 3060lbs. I chase alcohol burning, roller cammed, aluminum headed sm block chevys all the time."
Wallace Calcs says close to 700 hp for the weight to ET and that with ported factory cast iron heads.........You know the ones people throw away because they cant make power.....
Where is the link to that? Don’t think I’ve ever seen that build.
LOL... This is an extreme far stretch from the normal Joe building a 500 horsepower 318 LOL... One-off custom fabricated pushrod stabilizers... One-off custom valvetrain girdle... LOL.. don't forget you need a friend of a friend who just happens to have a set of RT super stock heads that have been massaged and they're in great condition LOL...
nice build. not quite 500 and the other 23 hp will require more compression, more head, more cam and more rpmLOL... I think the closest will be the article with 477@ 6500 rpms.
That’s YOUR problem, not mine. You don’t like the numbers, don’t look.
Do I need to mention the one-off custom ground crank buy a custom crank grinder... Or the knowledge of bushing and blocking off oiling passages and the ins-and-outs of using Chevy connecting rods LOL...
Oh I guess it can be done but instead of doing all that if the normal Joe could... LOL.. most would just stopped to spend way way less money cobble together a 360 Stroker and make life simple...
LOL, I don't have a problem at all. But you sure blow a lot about what you've done and will do, but never back it up. Reminds me of the old saying, "the proof is in the pudding".
It has been a few years since I had one of my own, but isn't a time slip "just a piece of paper with numbers on it"?
What you think of what I do doesn’t mean **** to me. I’ve spent my time at the track, with all the dickheads, morons, fence leaning nose pickers so again, I don’t care what you think.
Get over yourself.
Now that is REALLY funny, the pot calling the kettle black.
I got over myself years ago, that's why you don't see me blowing about how great I am or acting like a 12 year old girl when some one call bull **** to something I post. If you talk the talk, walk the walk.
Really? Call bullshit all you want. I can promise you I was at the track, getting paid to be there when you were shitting your pants and sucking your thumb.
Because of **** sticks like you, I don’t post a lot of results here. Plus, people who PAY for it may not want it posted. Know nothing, loud mouth morons who think the track is the do all, be all, end all and it doesn’t means **** to me.
Hold on a minute I wasn't saying none of that! You just said that and said that I was saying that! I said nothing about putting trick flow heads on anything I said nothing about something that couldn't be done... This is like me saying right now-- did you say you were having problems coming out of the closet? I mean for crying out loud what are you come up with this stuff....That engine was built 13 years ago for a dyno competition, the guy that owns it was on another thread saying he drove and raced it for like 10 years.
It's not meant to be a build that you copy but the main idea how is there. In the article he states how he would do a simplified version that anyone could build. The availably of parts for building high hp sbm now is a lot better compared to then. Your saying a set of trick flows or similar heads with a big solid cam and around 10 or 11 + to 1 cr can't make 500 hp ? Don't think anyone saying 318 is the best way to go for 500 hp, to me anything over 425-450 hp I'd start seriously thinking Big Block maybe a stroker sbm but to me they don't make any sense. Under 425-450 hp any 318/340/360 would do.
Bahahaha... Wait a minute... LOL...What you think of what I do doesn’t mean **** to me. I’ve spent my time at the track, with all the dickheads, morons, fence leaning nose pickers so again, I don’t care what you think.
Get over yourself.
And grinding 5lb off the correct places on the crank? I can do that here at my house?...First of all, those heads aren’t trick, unless you are running Super Stock, and no way would I have used them. Stud mounted rockers are JUNK. You won’t find many even basic SBC’s out there running stud mounted rockers any more.
Second, all that work on the crankshaft is overrated. He could have reduced the diameter of the counter weights and used a crank scraper and been better off.
Third, you can tube the lifter gallery with a hand drill if you have the common sense of a stick. It’s not hard. And it’s not trick. It should be done on ANY engine with solid lifters and any engine with hydraulic lifters where you want to control oil leaks.
Fourth, using chevy rods is a no brainer. Bearings are cheaper, easier to get and have many more undersized available.
That’s a basic prepped short block, with 10.5:1 for the rules and a solid lifter cam. The heads damn sure ain’t trick flows and most likely aren’t as good as a set of chinese heads with good porting.
Again, it’s not that hard. Nothing trick.
YR... Reach for the medication bottle and take a couple...lol...Really? Call bullshit all you want. I can promise you I was at the track, getting paid to be there when you were shitting your pants and sucking your thumb.
Then you must be about 85 because I'm 59, so I've been around a day or two.
I do agree with you about a dyno being a tool, it's a comparative tool like a flow bench. My motor was broke in and tuned on a dyno and the money spent for the dyno time was the best spent money of the entire build.
I don't act like a 12 year old girl so I'm not going to get into a name calling match with you.
