mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,269
- Reaction score
- 157
Hey guys, i appreciate all the help and suggestions
Pinion angle is definatly a problem and will be getting fixed before anything else...im going to go one step at a time and see what helps and what doesnt...Going to be getting some shims to set the pinion angle down to about 4 degrees nose down (please chime in if this is too much/too little for a street strip stick car)
If that doesnt fix it, i will be going to a different shock, and i feel i probably will...mopar340dave, i dont have those ones, mine are part number C2620...maybe i will order a set of the ones you have...should they work ok on my car even though i dont have the ss springs? will they be too long or make the car sit higher?
I have the snubber still which i will also try once i make the change...if it still hops, then i will have to move to the SS springs or caltracs, but i will see when the time comes
also, does anybody know what factory cars came with a long shock? just in case i want to go factory non adjustable as im not sure how much the CE's cost
thanks so far everyone! I love how everyone tries to help! the variety of replies is great for getting an idea what needs to done!
