Brazilian Dodge Dart 76 (similar to 69 usa)
a friend aske for a new shot ot the carb problem
Hi thanks a lot :D
I'm thinking use a plate to match intake to the carb.. I'll keep posting photos..
Congratulations on your promotion , Alex ! :cheers::cheers::cheers: !!!
On your carb gasket : it almost looks like it s a fuel bowl-to-throttle body gasket ... but , then again , what do I know ?
just have to paint it
I putted a new rear and front seal..
remove old seal was the hardest work...
Pictures are self explained.. any question, feel free to contact me!
in the middles of 2008 I bought my first A body... and dart sedan
I built an Mp3 player fot it.. never used :D because I got original k7 player
but mp3 is fun.. I used an old k7 player (it was damage I think)
[ame="http://www.youtube.com/watch?v=QkYJ3mOds0g"]YouTube - old stereo k7 player mod to mp3[/ame]
the carb looks like it sits off to the one side a little more then the other,,,like maybe the mounting holes on the intake are drilled of center ?????
i can see you have the proper spread bore intake,,they do make a spacer/adapter about 1/2 inch thick,,to use on intakes that are not spread bore design, with a spread bore carb like yours,, but i dont know if the spacer/adapter is wide enough to cover the part of your carb that is not sitting on a solid surface,,
A member of brazilian dodge dart list said that I have to put a thin plate (about 1/4"). He wiil look for me and give me one..
I hope this works :D
I will also buy a piece of phenolite to try to build an adaptor plate by myself
images are better than words (in this case)
looking good,, bet it would be a nice wheel stander with that rear engine in the first pic
It is the second time I use my dad´s car to bring 318 engine home.. it is a GM Kadett (Opel Kadett). It has a 1.8 engine.. it is a good and strong car. but I have to lay down rear seats to engine fits de trunk.
I use the wheel stander to move engine all around.. note that I let K-member up it, and I attached engine to the k-member. than I pushed engined to the engine bay.. (me and a friend lift the car body, while my neighbor pushed the wheel stander)
by the way, I bought the wheel stnader in a junkyard.. less than 20$
I dicided to make a carb plate and solve my spreadbore bore problem
I bought a pice of wood (phenolite)
Then, I draw the gasket holes into the plate
Marked circle centers
Finally, I made some holes using circle saw and wood bits
I´ve been working a lot to prepare my car to move to another city..
I did not finished body work but I have to put wheels to make easier. I'm desperated! Time isn´t on my side :D
some pictures of my work yesterday
By the end of the day, rainned a lot... it made my work hard.. Had to stop for a long time
A big mess.. Had to put all tools and part together to protect from water
Finally car is on four!!!
the final carb plate.. I sanded it to make it smooth
Now I will make a custom gasket
Had some problem with water pump
alternador also did not work.. I'm backing to the original with outside voltage regulator
how did u test the alternator ?? and whats with the water pump ??? looks a lot different then the water pumps in the U,S.
the problema with the alternator is the format.. the bar to make belt tide does not fit well.
them I will use the original with external regulator. More wires but will work!
the water pump has one little difference.. the side where water goes.
I hade to ajust because pulley wasn't aligned. Them, I think it bended the pulley "holder" as show in attached photo
sorry my terrible english. Today I did not any grammar/spell check
dont worry about your english ,your doing fine, not a problem figureing out what your saying,,i wouldnt do half as well if i tried your language,,,,
as for the alternator,looks like an american GM unit??? WILL REQUIRE DIFFERENT wiring,at least compared to an american wiring, you could always make a bracket off of the K frame or the car frame rails and use a turn buckel, like a lot of the street rodders do,,,
the water pump i cant tell whats wrong in your pic,,and it looks a lot different then an american pump,, cant wait till you fire it up
Carb and original alternator are resting in engine bay :D
I didn't like original alternator because we have to use an external voltagem regulator.. more wires.. more parts in engine bay.. more "visual pollution"
another shot
I also build some starter engine cables.. 10mm diameter the positive and 13mm the negative cabe
I've made a video showing problem with water pum.. I will upload it to youtube
note that when I put the screwdriver at the axel, it does not move.. but the pulley bases is not ok... I will try to fix it tomorrow (just don't know how yet)
[ame="http://www.youtube.com/watch?v=A1kx0cWpWew"]YouTube - water pump[/ame]
today I removed the water pump because it was twisting the pulley.. Maybe the water pump axe is damage.
I also used a little help from my friends to install doors... Now car is almost prepared to the "big moving".. just a few weeks to a new life and city!!
last saturday my friends and me worked together
I was (and still) so happy with result that I jumped and danced with the engine sound
[ame="http://www.youtube.com/watch?v=NDXn7sd5VEk"]YouTube - We got Fired!! Mopar 318 engine first run[/ame]
:cheers::cheers::cheers::cheers::cheers::cheers::cheers::cheers::cheers::cheers::cheers::cheers:
We're testing engine without gas pump and also without water pump.. thus, each test was just for a some minuts.. 3 minutes I think...
as the engine was without gas pump, we did not get carb working at iddle speed
tomorrou I will install gas pump. Thanks to JP the gift 8)
[ame="http://www.youtube.com/watch?v=RAvTFQz4Rqw"]YouTube - Onde há fumacinha, há fogo![/ame]
