Really? I have seen adjustable rockers with hydraulic lifters take anywhere between a 7.05" to an over 7.5" pushrod. No way in the world I would try it without measuring first. Just too many variables, not the least of which was Chrysler's absolute terrible deck height finishing. Most were way too high.
Then, throw the engine's history in the mix.......you're talkin about up to a 50 year history. No telling what machine work has been done previously, what thickness head gaskets, what lifters you're using......and on and on.
The optimum adjustment is to have between 1-3 threads protruding through the rocker arm on the pushrod side. With too long a pushrod, there is the chance that the top of the pushrod cup will contact the rocker and result in broken parts.
With too short a pushrod, there is a chance the adjuster ball will break off from too much length with the pushrod having too much angle on it.
No sir. The best thing to do is measure, measure, measure. And get it RIGHT.
