What is the relay box out of I'm looking to do something similarThis is what I had to do to close my hood.View attachment 1715573286
Thanks for the info that's the route I'm going to take just couldn't tell from the pic what box you usedIf you make a electrical drawing of the relay box and how you want to power the relays either sinking or sourcing, it will make it easy peasy to power up everything. I made a electrical drawing of all the circuits I had to modify to make it work and will help out when I have to troubleshoot problems.
I'm beginning the installation in my 70 non-factory air Dart. I bought the perfect fit with the blue tooth diagnostics. It came with Installation Manual 1967-72 Chrysler "A" Bodies, Document #1-3062 Copyright 2021 ClassicAutoAir / 07.21
The booklet looks to have been designed by somebody in high school. It's not totally awful but it's also not great. One example is an illustration on page 23. It shows the installation of the heater box from the engine bay view. It's showing you to use two supplied bolts to bolt the box to the firewall. The problem is that it looks like you will have to drill two new holes with no instruction on where. After careful examination of the heater box and the firewall, you realize that you are to use two of the existing holes from the old fan motor.
Another lack of explanation is Bench Calibrating the system before installing it in the vehicle. Pages 9-10 are titled "Operation" and show all the positions of the controls and what should be happening with the unit. Then you get to the middle right of page 10 and it reads "Your controls are now fully calibrated to your unit...." Wait, what? We were calibrating? How? And on one of the bags in the box it says you must follow the steps in the BENCH CALIBRATION packet before installation. There is no packet for that. I was poking around their website and under "Support" I found a video on how to bench calibrate. The installation manual looks like it was not written by a technical copy writer and more like something that was deemed to be too long so they edited it down and then never went back to proofread it to see if it made sense.
I also found that my temperature slider only has half the range of travel. I looked at the supplied Temp Control Integrator, which is a sliding potentiometer, and it only has half of its range of travel as well but the opposite direction. If I shorten the wire 3/4" and make a new loop, both the temp control slider and the Integrator will have full travel.
I'd be interested in hearing any other experiences on installation of the newer system. I expect to have to do a few modifications but leaving out important information is not so good. I mean how difficult to print, "IT IS MANDITORY THAT YOU CALIBRATE YOUR SYSTEM BEFORE INSTALLING IT IN YOUR VEHCILE. VISIT THE SUPPORT PAGE ON OUR WEBSITE TO VIEW A SIMPLE HOW-TO VIDEO"
And the bolts through the firewall, it would just take a few dashed lines directing the bolts through the two holes on the drawing to illustrate that. Simple.
It is just for the valve only. After I got mine running I had my wife open and close it so I could se the travel of the valve. So I could adjust the switch where I wanted it.I'm in the process of installing this kit right now in my 68 Barracuda and I also had the issue where the temp control slider only had half the range of travel and wound up having to create a new loop in the wire.
Does the temperature slider work the water valve as well as a blend door inside the box or does it just control the water valve? Reason I ask is that I noticed that it only takes about 25% travel with the temp control slider in order to have the valve be fully open or fully closed. It's as if the potentiometer has too wide a range of resistance. Either that or the rest of the range of the slider controls a blend door inside the box but I never heard anything moving inside the box when I continued to move the slider the rest of the range.
Just installed this kit in my 1970 Dart. The position problem with the temp slide seems to be universal and Classic doesn't seem bothered by it, or interested in fixing it. My temp slide seems to work correctly now that I modified the wire to provide full travel. On my car when I tried to put their adapter on the dash defrost vent above the controls and then tried to install their hose it all interfered with the function slide - I got rid of their adapter, installed a section of original hose and ran their smaller hose up into it. It all works fine at this point. The other big issue that I ran into is that the bracket on the box that is toward the inside of the car was impossible to mount because there was no way to get to the top hole to drill into the cowl without removing the whole dash frame from the car. I turned their bracket around did some bending, and added a bracket to the cowl so that the holes could be drilled through the glove box hole.
I didn't like their glove box so I took a later model plastic glove box and modified it to fit and then mounted their control box (where all the wires go) inside the glove box as well as the relay.
There were also belt clearancing issues with the compressor at the thermostat housing and the water pump neck fin (just one). The brackets came from Bouchilon (printed right on them) and Bouchilon knew about these needs and got me going. The big aggravation to me is that the compressor has 2 belt grooves and the crank pulley has 2 grooves for them but they don't line up so you can only use one belt and Classic and Bouchilon both think this is just fine ((grrrr)). I will eventually do a bunch of work to move the crank pulley out so both belts can be used, but then you have to space the water pump pulley (shallower pulley) and the power steering forward so that they line up with the crank. This by the way is on a 1970 motor with the aluminum water pump so your 68 would be completely different.
All in all I have had this installed and fully operating for 2 months and maybe 500 miles and it works great, but a Perfect Fit??? Hell NO!!!
I had the same deal with the heater valve control. I modified the wire and I never checked the effective travel - it was closed in one direction, and open in the other and half way in the middle and that made me happy. I sent pictures and explained the situation to the tech support folks and they didn't really seem to care or want to work with me to fix the situation for future buyers.
Have you tried to install the defroster hoses yet???
I started with an original AC firewall with the BIG hole for the blower, so I never got to see how the unit would have fit as intended as I had to make brackets to adapt their stuff to the AC firewall - fortunately somebody here had already done this and provided a template for the conversion.
I also didn't like the idea of just installing the water control valve to the hose and letting it flop around, so I fabbed a bracket to hold the valve
The bracket holds the valve and the return hose and the AC hoses run under the bracket to hold them on the top of the fenderwell and attaches to two existing holes in the face of the fender well.
In my experience, if you know what you want from Classic and go through the tech support folks, they will send replacement pieces to make things work better. Please keep posting on your project. I'm taking off on a loooong road trip (over a month) so hearing what might fail before it does is a good thing!
