ESP47
My Duster didn't originally have a console so I just made my own. It's not quite in the factory location, it's located to put the T56 shifter in the middle of the top plate so it's a little bit further back than the factory console location. Probably only a few inches though really. The front mount is just a piece of flat stock I bent up, the rear mounts are a section of rectangular tubing leftover from making a set of frame connectors. I just cut a slice of the end that was about 1.5" wide so I had an open rectangle and then cut it so it was the right height to meet up with the console. Wasn't going to pay $90+ for the AMD reproduction brackets, especially since they still might have needed modification for the T56 tunnel anyway
Hey I don't blame you for not shelling out the money and it's not like anyone is going to see underneath it anyway so it doesnt really matter if it's factory as long as it holds the console in place. I've got a pretty nice auto console and have been pondering over a TKX swap for a while now. Thinking about buying a 4spd top plate and running it that way. After seeing how minimal the cuts need to be with this new torsion bar hoop, I might actually go for it. Can probably keep my carpet and still have the classy looking console set up in there while still keeping it looking stock.
