69_340_GTS
Are you sure the fluid can flow thru those kinked up sections?
What happens when you drive it? When I re-did my brakes the brake pedal would keep going soft. I drove it twice and re-bled the brakes twice, and the pedal finally remained firm. My theory is that when you drive it, bubbles either form, or they break free from somewhere, and cause a soft pedal until you can get them all out of the system.
I've been having my wife let the pedal fall to the floor before I close the bleeder, maybe this is why it's not bleeding perfectly? Should I not allow the pedal to fall to the floor? I read on here just now that it can "trip" the proportioning valve."
Good job ! Looks like all your ladies are hooked from the picts !! Nice work.
I like to do some things just once. Removing and replacing an automatic transmission is not something I want to do if I don't have to!
Just curious? Are you looking for more performance? Ive heard talk of cam, converter etc..
I understand always working on the car. I think you have some power that can be brought out by some engine tuning. A good baseline would eliminate all guessing, get this thing on a chassis dyno. If it were me I'd be looking at installing some proper gears out back..
Those gears are a good compromise for a driver. You carb OTB is good enough to let the car run. However, between the carb and your ignition there is some power hiding in there. I googled chassis dyno in vegas and multiple popped up instantly. I'd give them a call, probably much more reasonable than you think.
