Cover the timing tape with clear packaging tape.
That is the only way I have been able to get them to stay on.
I was thinking of spraying over it with a clear enamel.
I tried that once, it did not work.I was thinking of spraying over it with a clear enamel.
that's the way i always do it, works well for me.I was thinking of spraying over it with a clear enamel.
who is driving
The little boot and foam gasket go inside the car, and attach to the floor pan. It seals the twist shaft that goes from the console down to the transmission. When you pull the carpet out, you will see the round place on the side of the trans tunnel where you need to cut a hole in the floor for it to go thru.
I'm scared to take the carpet out, it's already not very good carpet. I dont think it's actually carpet made for the car
go ahead and order new carpet, don't stop now LOL
Oh, come on Doc! In order to fix peoples teeth....you have to stick your thinly gloved fingers into their nasty Corona virus infested mouths'. I would think carpet would be a cake walk....lol. Don't be skeered! It's 8 nuts on the seats and about 10 phillips head screws on the door sill plates, and then 4 seat belt bolts and the carpet is laying out in the floor. You're 10 feet tall and bullet proof....you can do it! Ready......BREAK! (end of pep talk)
It's scared knowing if I take it out it's going to fall apart and I'll need to buy new carpet.
Oh Pshaw! Clearly you have become a master at buying parts that slip under the nose of your Finance Committee Chairman. You know you want new carpet. Just hit the "Buy Now" button and be done with it! You know you will get there sooner or later, today might as well be the day!
Oh, and don't forget, if needed I offer a no-cost service spending other people's money. Feel free to call on me any time.
Aww,Man! That sucks.Well this sucks... I mean trans oil still goes through it but it definitely isnt good... I guess I will have to look for some...
Then even more sucky... I scratched the car
Yup. It works on the other end.only concern is dont let it droop. too bad you werent a neighbour, would throw it up on hoist and fix it just for fun...
