Very true.Yeah if I wanted peak power I would have put in a roller cam to start. Its a slippery slope as they say
I'm not saying that there's zero merit to it, I'd probably at least see what the formula say when shopping for cams.I'm sure it's a valid formula, in application, and certainly better than just guessing. I'd use it in a heartbeat to select a cam. I certainly don't have anything better to use and I wont purchase several cams in the pursuit of perfection. I think for most guys we just need it to be as close to "right" as possible, out of the gate. We're not gonna be swapping around a bunch of cams to test. So in that way, it probably works well.
This is what I'm thinking.All that said. I think it's far more a correlation, than a real explanation of some underlying principles at work.
I think the part that most miss, the part I like the most, is you supposed to subtract duration to keep overlap, eg.. Say your gonna go with a 286* on 114 but instead go 274* on 108 both should have similar overlap Idle etc.. The 274* 108 should have better bottom and mid range torque while I guess same overlap suppose keeps similar top end.I'd say from what I've seen you're gonna get a pretty gnarly sounding cam with that formula.
Your suppose to calculate lsa, pick an overlap and calculate duration from the two. But other then a chart he really don't give much on how to pick the right overlap.WHERE in the formula does it include duration? Or anything else for that matter?
All that's just too much to keep track of. No thanks. lolYour suppose to calculate lsa, pick an overlap and calculate duration from the two. But other then a chart he really don't give much on how to pick the right overlap.
Yeah and that in and of itself disproves his theory right there. How many big block cars have been outrun by STONE STOCK 340 cars? A frikkin lot. So that tells me those 340s worked pretty dang well just like they were. ....and here comes the "yeah but they couldda been better" crowd. Horse ****. They were great like they were.The way I see to use it pick you cam like you normally would and then translate it to his formula, Say a 2.02 360 9:1 and gonna use a 340 cam, the formula says about a 106* lsa, so every 1* degree tighter is 2* less duration, so 114 to 106 = 8* so 16 less degrees of duration so 252/256 on 106 instead of 268/272 on 114.
having raced my stock 340 on chit tires and the chit stock carb@80k miles 3.23 727 14.3@97 plus mphYeah and that in and of itself disproves his theory right there. How many big block cars have been outrun by STONE STOCK 340 cars? A frikkin lot. So that tells me those 340s worked pretty dang well just like they were. ....and here comes the "yeah but they couldda been better" crowd. Horse ****. They were great like they were.
Absolutely!Yeah and that in and of itself disproves his theory right there. How many big block cars have been outrun by STONE STOCK 340 cars? A frikkin lot. So that tells me those 340s worked pretty dang well just like they were. ....and here comes the "yeah but they couldda been better" crowd. Horse ****. They were great like they were.
Everyone seems to miss the whole point of this thread, it seem most peoples responses are based on how they feel about DV, not the dyno results in the guys video I posted, doesn't seem like anyone has look at them.1978 Crane cams catalogue, SB Chev. Has 26 flat tappet grinds listed, hyd & mech. 8 are 108 LSA or tighter.
Fast fwd to the 2010 catalogue, which was after DV did the cam testing for Crane.
73 flat tappet grinds, hyd & mech. 32 were 108 LSA or less.
[1] Used SBC because there are more grinds gives a better numbers spread.
[2] The above cams do NOT include oval track grinds which are often on tighter LSAs.
[3] The numbers speak for themselves.....
Ive already watched them tighter lsa= less vacuum @ idle but better low mid and high up to around 6kEveryone seems to miss the whole point of this thread, it seem most peoples responses are based on how the feel about DV, not the dynos results in the guys video I posted, doesn't seem anyone has look at them.
But if you go by DV when you go tighter lsa you also go with less duration which keeps the same overlap which should have similar idle driveability etc..Ive already watched them tighter lsa= less vacuum @ idle but better low mid and high up to around 6k
alot of people dont want the lope
prolly why the factory ram wider lsa
boosted cars seem to like wider lsa
when i buy another cam it will be 108 lsa
ill take both tyBut if you go by DV when you go tighter lsa you also go with less duration which keeps the same overlap which should have similar idle driveability etc..
My take away that DV main point is, instead of sacrificing lsa for duration, sacrifice duration for lsa.
yes sir.Oh and when you say "valve size" in the formula, I am assuming INTAKE valve size?
True but most would generally calculate what most would consider tight lsa, A small displacement with big valves and high cr would have a fairly wide lsa. EG. a 13.5:1 289 with 2.08 valves = 115* lsa and even that's not that crazily wide.DV never said a narrow LSA is better! You have to choose the right LSA for your engine combo!
I tend to agree with that statement.273,
I am not missing any point....& most others aren't either. DV claims that cams sold by cam companies are generally too wide with LSA....because the cam company wants to save the hotrodder from him/her self, so they widen the LSA. DV says the correct way to moderate the function of the cam is to reduce duration.....not widen the LSA because power will be reduced; he has dyno tests in his books.
Are they available to us ?How many dyno tests does he have to do?
It's one of the dyno results the guy uses, no one is arguing with that going tighter generally makes more mid range torque that's common knowledge, the question is does the formula get you optimal lsa and does this optimal lsa gain you 40-50 lbs-ft and get you near the 1.40 lbs-ft DV claims over the 110-114 most cams are ground on? What was the gain of this eg., like 10 lbs-ft or so 108 vs 112 most would be glad to lose 10 for driveability.Richard Holdener did a LSA comparison on a 5.3L LS engine [ three cams, identical except for LSA ]. The tight LSA cam made more average hp everywhere & IIRC, it actually made a little more at peak hp. So modern engines also like tight LSA. Maybe someone can link it.
No one arguing that, like saying does more duration tend to make more hp, question is does running tighter lsa then the formula recommends are you still gaining torque? And in the eg.. The guy shows seems you will, if that is true how's the formula recommendation optimal ?Every test I have seen shows tight LSA is better. The late Joe Sherman was quoted as saying 'The tighter I went [ with LSA ], the more power I made '.
Just like everyone would expect, the question isn't does tighter lsa give more torque, it's does the formula give optimal lsa and more important match the claims of being up there choosing cams like 1% of engine builders.Here is yet another LSA test. Long before the 128 rule was known. Three big duration cams in a 350 Chev. Isky cams identical except for LSA: 106, 108, 110.
The 110 made 3 peak hp more than the other two : 583 [110 ], 578 [ 108 ], 580 [ 106 ]. The 106 made peak HP 500 rpm earlier. Average tq through to 7000: 106 was highest, 108 was down 13, 110 was down 23. In percentage terms, the 110 was down 5% on the 106 in average tq.
Like said before you could probably do worse than using the formula as a guide line.Much to much criticism of the 128 rule. It was created so that hot rodders didn't have to guess LSA. DV wants you to buy his software program, which gives more accurate results. 128 was a freebie...
