j par
Well-hung Member
.,.. actually I'd like to do some more cutting out of my car as well...
thought you were trying to get your car more street and user friendly?? Thought you removed the cage, lexan windows, etc etc.....View attachment 1715488918
Taking out weight were it's not needed doesn't hurt anything... it's supposed to be a triple threat car... Street, strip, show...thought you were trying to get your car more street and user friendly?? Thought you removed the cage, lexan windows, etc etc.....
power boosters are generally really light. I want manual brakes just to save room under the hood and eliminate a vacuum hose.Most people probably know this, but you need to make sure your new master cyl has the groove for the rubber retaining ring. Also. I had to shorten the pushrod as the pedal was too high. 318WR has this covered with his adjustable pushrod.
As for the manual steering box, I'm assuming it's shorter than the power steering box. Do I need something like this ?? It adjust 17.5 to 26 inches.
cheese slice derby car?View attachment 1715488918
Do you have a certain year master cylinder that has the groove? Which one did you use?
https://www.ebay.com/itm/New-Lower-Steering-Column-Shaft-For-Dodge-D-W-100-150-250-350-Pickup-Ramcharger/123859573066?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
FIXED....
I fixed it for 318willrun's thread you're only supposed to show a little corners and bits of it LOL....
Oh trust me I'll live LOL it reminds me of a fan dance where the lady is naked but she keeps the feathers over the good parts LOL...Man! That little piece of paper really bugs you doesn't it?
I ordered one of those lower shafts. I measured mine and it's about 18" with power and I'll need about 23 inches with the manual box. And yes, I believe my master cylinder is aluminum.I really do not know on the steering box, but I would assume you are right.
Trust me, it's killing him. It kills him to think I danced his song 25 years ago and it has him on ropes.... so I'll let him play with the ropes till he hangs himself ... LOLMan! That little piece of paper really bugs you doesn't it?
Trust me he dances around that 12 second time slip like it's gold LOL what's killing him is in 35 years of hot rodding cars he still doesn't have an a body Mopar time slip as quick as mine LOL......Trust me, it's killing him. It kills him to think I danced his song 25 years ago and it has him on ropes.... so I'll let him play with the ropes till he hangs himself ... LOL
and you would know this.... LOLTrust me he dances around that 12 second time slip like it's gold LOL what's killing him is in 35 years of hot rodding cars he still doesn't have an a body Mopar time slip as quick as mine LOL......
FACT...and you would know this.... LOL
OK, back to the Hot Rod Truck!!!
you said "FACT" I've never done 12's, when I post a slip you have more facts.... LOL Fake News more like it Remember, this isn't about You vs Me. Never was...FACT...
Do your research, quote me where I said it was a fact you didn't have a 12 second time slip or stop making stuff up.. no this is about your non-truths, alluding to stuff that never happened...(better than 12)...you said "FACT" I've never done 12's, when I post a slip you have more facts.... LOL Fake News more like it Remember, this isn't about You vs Me. Never was...
OK, BACK TO THE DRAG TRUCK!!!
How many times have you stated "ET slip or it never happened... you'd post it if you had it.... blah blah". I will share this one FACT, and this doesn't include paint, rims, or any cosmetics. It cost you 4 times as much on a engine to go the same ET as me. If I spend 1500, you need to spend 6000 to run with me. That IS a factDo your research, quote me where I said it was a fact you didn't have a 12 second time slip or stop making stuff up.. no this is about your non-truths, alluding to stuff that never happened...(better than 12)...
And besides that your 12 second time slip was about to cheesiest attempt to post a time slip I've ever seen..
this is steering we are talking about. Not a motor mount.Okay keeping with the truck.. if you paid $45 for that shaft that's half the expense for your Harbor Freight welder... I would have cut my shaft in two, got a 15 inch sleeve and put five inches at either end of it. Then I would have drilled it and pinned it and then also welded it...
I don't care if it takes a million times you're not going to get the last word on this by saying back to the truck....How many times have you stated "ET slip or it never happened... you'd post it if you had it.... blah blah". I will share this one FACT, and this doesn't include paint, rims, or any cosmetics. It cost you 4 times as much on a engine to go the same ET as me. If I spend 1500, you need to spend 6000 to run with me. That IS a fact
Now, for the 3rd Time, Back to the DRaG TRucK
that's why I said I would pin it as in drill all the way through both of them on both ends put a bolt or something through it and then weld them at both ends as well with a tight-fitting sleeve..this is steering we are talking about. Not a motor mount.
How about my brothers Nova, it runs 8.90's ??? Do brothers count?? My nieces Camaro, it runs 9.90s... do Nieces count??? LOLI don't care if it takes a million times you're not going to get the last word on this by saying back to the truck....
You say about spending all this money but how much have you spent on all the different cars and trucks and vans? All the different small block and big block aluminum heads and small block cast iron heads LOL... We're talking about drag racing here correct? You know where Time Slips rule... I by no means have the fastest but it's faster than yours or anyone you can come up with especially in an a body not your best buddies Chevy......
I would long trust my drilling and welding before some offshore made knuckle that I see in that picture...that's why I said I would pin it as in drill all the way through both of them on both ends put a bolt or something through it and then weld them at both ends as well with a tight-fitting sleeve..
