brsmustng99
Active Member
Mbaird, how does this solid flat tappet cam look from hughes Engines?
Who is Porter??That’s quiet a cam for a 340, if you wanted to add some compression, a good single plane intake and some gears to wind it up I’d say it would run good.
I ran a older Hughes fs in my 408. The cam was 260/264 @ .050 with .62?/.64? lift IIRC. The engine had ported Edelbrocks that flowed in the mid 290’s, 10.8-1. It ran 6.57 @ 104 shifting at 6400 in a 3260# 69 Dart.
I ran the same heads on a 340 with a Hughes hydraulic, 237/242 @ .050, the lift was a little under .600”. It was 11.4-1 and ran 7.24 @ 94 and change in the Dart. Also shifter at 6400,I tried more and less rpm’s with both engines and 6400 was what they liked.
Call Porter and pick his brain on the cam, he won’t steer you wrong.
Who is Porter??
I changed my home ported edelbrock heads on my 410 to trick flows but also changed my cam. Went from a hughes 234/238 @ 50 with 530? lift on a 110 lobe sep to a custom Howards 237/243 @ 50 with 610 lift and 112 lobe sep. used to make 392rwhp ,now makes 425rwhp. Revs were all done by 5800 before but now revs cleanly to 6400.Car behaves much nicer with this cam and almost feels like I have put a smaller cam in it. Last time at the track I ran 11.5 @119 mph but have not been to the track with this set up yet but it feels faster on the road as it revs real clean now and brakes into wheelspin any time you nail it in second gear(5 speed manual)
I have 11/1 comp and it is a 5 speed manual! Yes I requested a wider lobe sep to calm it down a bit because it is a manual and I am 66 years old so wanted a nice car to drive. Yes the chassis dyno shows a drop in torque but it doesn't feel like it on the road,just smoother and better behaved. Are you saying my sixty foots will blow out? Remember I have a manual and best results before were dropping the clutch at a low twelve to fifteen hundred revs but I can experiment and drop the clutch at a much higher revs to make use of the power band in the cam.
Quality machine shops are getting very hard to find !!Not if you aren't going to take advantage of the additional potential provided by the new heads. I don't think it's fair to disparage the TF heads which were replacing a very good head to begin with. Considering the IMM EQ head isn't available anymore, there aren't too many options available for something in that performance range ready to go out of the box. What's the next best iron head? The SM heads have potential but need to be loved on by someone that knows what they are doing. Good head porters aren't a dime a dozen. Around here I haven't found one that has a flow bench, everyone is just going by eye. So now you have another $100+ in shipping them around to make sure you get a good job.
when it comes to a stick, i am clueless what it will do.
I do know with a 5k convertor, it left like a dog compared to the 107 cam i got talked into pulling out for the 112.
Motor was a stroker with 11.5 ish compression.
Moral of the story, wide LSA likes tons of compression and extra convertor on a typical non elite headed motor. It typically shows up in the 60 foot.
I'm curious what the 60' times were and what the change was. Mine short times in the 1.50's. I'm pretty happy with that for a heavy car on street tires. I run a 4,000 convertor. technically I should be running a 5,000 given the TQ RPM but it's 99% a street car.
