pishta
I know I'm right....
soo subscribed! This is my next project with a 273 and a smaller turbo, flipped mag logs and all. What size carb again?
Initially I'm going to just pull a few degrees and run it as-is. I'm not planning on pushing it past 5-8 psi. And with E85 I should have some wiggle room on timing.What are you going to use to control your timing?
750 DP converted to E85 blow thru.soo subscribed! This is my next project with a 273 and a smaller turbo, flipped mag logs and all. What size carb again?
I'm getting close to buttoning up my turbo conversion and thought I'd share some pics on my progress. Car is a 65 Valiant with a stock bottom end 5.9 Magnum and EQ heads. In it's current trim it runs the equivalent of low 12s, in the 1/8 mile. I'm hopping to make it more streetable and dip down into the 10s.
Build is an Ebay GT45, Ebay Wastegate and BOV.
I fabbed the hotside out of 2.5" mild steel. Downpipe will be a 4" necked down to 3" and then T'd into my existing dual 2.5" exhaust to the bumper. The downpipe is really all I have left as far as fab goes....and maybe a few other small pieces.
Carb is an older 4150 DP I converted to E85 blow-thru with the Quick Fuel metering blocks.
It runs regular 7.90s on the 1/8 with a best of 7.65 on drag radials and through mufflers. It's "all in the combo", as they say. It currently has a 4.30 spool in it, which helps my times but I'm hoping I can drop that to a 3.23 or lower and still pick up some time. Getting closer. First start up was last night. Thanks.Your 12's in the 1/8th mile? I would think your N/A configuration should be running 8.50's in the 1/8th.
Turbo with slicks should dip into the low 7's or high 6's,again with traction.
By the way your work looks very good,a patient fellow..
Can't wait to see the first ride video. Great work!Man that's nice, great job!
If I show you too up-close you might get scared of all the mutant caterpillars crawling all over where normal welds should be!If you think of it I bet some of us would appreciate more detailed photos of the "tight spots" like the exhaust, etc and underneath. Man that looks good
With this motor and my modest goals I'm going to keep it under 10psi and try to make it last and enjoy it. And until I get the carb dialed in or switch to EFI (probably the FiTech) I'll keep pressure on the very low side ~5psi.Nice work! How are you gonna do all the tuning to the carb and timing? Are you gonna increase boost to a maximum safe level? Or just be happy with 8-10 lbs and call it good? I rented a dyno by the hour on my last engine build, Was well worth the money! Picked up a good 65hp by bumping the jets almost 10 points. Plan on doing the same when I get my turbo build completed.
A lean burn Distributor has no mechanical and is able to accept vacuum pod and breaker plate. Simple and safe. 20 degrees initial and a 14-16 degree pod... Well you get the idea.... FBO plate on zero should do the same thing.I'm running off mech advance only. Vacuum can is disconnected.
NA I was running 12 initial, was at 25 degrees at 2500rpm and 35 all in at 3000rpm.
