Being a carbed Magnum, a turbo combo... Subscribed...
Yes! One of the things I'm considering as I tune the carb. I've read that people have yielded great results with BRPVs. Thanks!Great Project! Have you considered using a Boost Referenced Power Valve?
Got manual dumps on it right now but will probably put some electric ones on it eventually.Similar to my old build except a big block.
Need to ditch the turbo mufflers as they are baffled. Get you some free flowing mufflers like Racebullets or glass packs. I just used straight pipe, no mufflers.
Nice build!
It does have the built in FPR, but I read on the turbo forums that the return port on the FiTech is really small (which I confirmed) and would not flow well in a high volume application like this. So, I'm going to use my Aeromotive but opened all the way and be the source for the return line (which is already plumbed) and let the FiTech regulator control pressure.I thought the Fitech had a built in FPR and that you didn't have to run one? What's the block on the firewall with all the hoses going to it, vacuum distribution?
First page has pics of the wategate next to the turbo. I'll see if I have any better onesIs there anyway that we could see some pictures of where the pipes converge and where you placed the wategate?
