daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
Fun watching this build since I’m right along with you on mine. But it’s just a V8 swap
over the top nice and a milestone for you.....anyone that has installed from the bottom will never go in from the top in anything with good paint on it. I was gonna say I would not want to be within earshot when you get your first scratch....but I do not want to jinx you.
Mopar to ya'
Denny
Yeah it's looks like your doing great job so far Kevin!Thanks John but I think I’m in pretty good shape.
Concur with JD!I think I would just pull the chunk, rather than the yoke. That way, you can get to it easier, and not mess up the pinion setting. Welding the nut would work best. If you break any easy out off in a bolt that small, you're screwed!
Most would!I probably will just pull the yoke. I did that earlier by marking the bolt when I put a new seal and speedy sleeve while doing the differential repair. I’ll see if I can get the bold out myself. If not, I may have to get professional help.I’m sure that my wife would agree that I already need professional help
