Phreakish
Which 600 setup are you using? As far as I understand it, it's only the 600 power adder that has the full professional tuning software.
That's what I was thinking. Mine is not the power adder system, sadly.
I just hooked up the control unit to computer and used it like a USB drive. You should find the pro software application setup there. Supposed to come with most all systems.
I've looked there. No dice. I've got the GO EFI 4 - 600 hp. None of the documentation even hints at being able to plot the data like OUTLAWD shows.
I do have the Power Adder 600, but I thought I had read the non PA also came with the pro software.
Will your control unit data log?
What I did was take my fuel learns, then apply those multipliers to the base VE surf I was using. The first iteration went well, but I think I went to far the second time around, as now it is adding fuel back in...
58 psi seems to be the regulated line pressure.
Pressure in the return should be minimal, if it gets much above half the line pressure, you can run into problems - but the line pressure is the real issue. Putting a fuel pressure gage on it would help determine if you really do need a bigger/better return.
I'm using the original feed as a return also with a 255lph pump mounted in-tank. WOT is fine for me.
WOT should be the biggest demand for fuel, so the return shouldn't be the issue. The return is most heavily tapped at idle/low flow times. How full is your tank? Possibly fuel starvation due to fuel slosh and an in-line pump? in-line pumps are notorious for starvation when the fuel sloshes..
I had the same issue with a full tank as well. The return fuel seems to be a pretty low pressure as when I turn the pump on it sounds like it it's just trickling out.
I wouldn't think you need EFI hose for the return, it should just be a low pressure bleed off. I would run regular low pressure hose to test it, and I'd be tempted to keep that hose on there if it fixed the problem.
Comparing the supply to return line I would expect the return to have a higher line resistance based on the following.
I have an 8an pickup line from the tank to the pre pump filter, then once it's at the pump I have 6an line to the small filter and then FiTech unit. This should have very little restrictions. Now for the metal 3/8" existing line that I am using as a return it was an oem copy but larger diameter. Measuring it appears to be 3/8" outside diameter. Then with the various bends, turns, etc I can see how this line would have a different resistance rating than my supply. Due to the resistance difference that's why we were thinking it could be an issue. If the return pressure is low could I do a quick trial with standard fuel hose back to the tank and see if it make any difference or at least eliminates the return as the culprit? I hate to spend $105 on efi hose for the test and if it's not the issue. If it does fix it I would swap out thw line to efi rated right away.
Anyways thanks again
You said your problem is mostley at WOT? Like was allready mentioned, thats when you need the MOST fuel, so return flow is probally not the issue. In your picture, you just have a pickup laying in the tank, with no baffles....I would suspect major fuel slosh and air.......
Again I doubt these have any affect but wanted to show you what I have.Last thing is that I have a 1" tapered spacer too on the LD340.
talked to FITech today in depth and they are pretty confident that they know what my issue is. I have the good ol points ignition system with ballast resistor and they are confident that's the issue. Sounds like the 6-7 primary voltage from the coil causes the ecu to improperly work causing my symptoms above 4,500 rpm's.
So next step appears to be ignition... What are you guys using for ignition/distributor as it looks like that's going to be this weekends purchase. I am planning on using their timing control so a distributor that's comparable would be great.
I have a reman electronic style dizzy that I believe would work if locked out but wanted to make sure.
At least it's something to go by... Anyways thanks again guys.
