wireweld
Will someone walk me through rotor phasing. I'm not sure I did correctly. Thank you.
Just curious if this is normal or needs adjustment. I was setting up throttle cables and noticed when I went to WOT the TPS sensor reads 96.5 max. I thought it was my cable adjustment but when I did WOT by hand at the trottle body it's read 96.5 max too.
Keep in mind I have yet to start the car and do any IAC adjustments yet.
Is this normal or should it read 100%??
Got my system together and....starts. Runs for a minute then shuts off.
not sure what's going on.
After It's really hard to start too. Keeps cranking and cranking till it slowly fires. Then dies after 30 seconds to a minute.
I'm pretty sure yours is gone already. PM me your invoice number or shoot me a work email!Will you make sure to ship mine after then?
Here's a new one, for me at least. After running for a month or so, my unit stopped working today. Power adder 1200, fuel only. The engine fires, but then immediately dies. I noticed that I don't have any RPM reading. It stays at 0. My regular analog tach reads fine. All other readings; MAF, Temp, AFR, etc. appear to be reading fine on the handheld.
I tried re-writing my saved config profile and power cycling. That didn't work. So, I tried resetting the default v8 profile. Same thing. Engine starts briefly and then immediately dies with no change in the RPM. I've checked my blue tach wire, reseated all of the fuses and checked all of the connections at the TB and at my power sources.
Everything else is fine. Clean fuel, good fuel pressure. Spark is good, cranking power is great. It just starts and in less than a second just dies, like somebody pulled the coil wire and the RPM stays stuck at 0.
Thanks. Yep, I checked that one.If your not using FItech timing and you saved or reloaded a setting make sure you ignition setting is set back to tach.
Same thing happened to me - twice. Pull the air cleaner and have a spray bottle or cup of gasoline handy; have someone crank the engine and when it fires up spray/pour gas down the throttle bore. If the engine keeps trying to run then it's fuel delivery. Crude, but it works. I did the master reset and that solved the issue both times.Here's a new one, for me at least. After running for a month or so, my unit stopped working today. Power adder 1200, fuel only. The engine fires, but then immediately dies. I noticed that I don't have any RPM reading. It stays at 0. My regular analog tach reads fine. All other readings; MAF, Temp, AFR, etc. appear to be reading fine on the handheld.
I agree. I installed the system in June and had idle and warm start issues. Cody walked me through those issues. On Aug 26th I adjusted the IAC below 10 and it's been OK since then.What is concerning is that it happened twice. Is there a setting getting lost?
Spoke to support. My unit is going back for an RMA. Disappointed but at least the support is very good.Here's a new one, for me at least. After running for a month or so, my unit stopped working today. Power adder 1200, fuel only. The engine fires, but then immediately dies. I noticed that I don't have any RPM reading. It stays at 0. My regular analog tach reads fine. All other readings; MAF, Temp, AFR, etc. appear to be reading fine on the handheld.
When I say OK, I mean just OK. I can't recommend the product, not when other guys I know have installed `other name brand systems and have had no where near the tuning issues. My Dart with a more radical cam and Eddy carb runs better and is more reliable than the Coronet.No problems since? I really want to get this setup soon, but the reviews have been up and down. Mostly solved though it seems.
